4.9 cwp for 5speed be3 gearbox
After a 4.9 cwp for a 5 speed be3 gearbox  , apparently fitted to early pre 2001 Citroen Berlingo / Peugeot expert 1.8 non turbo diesels , ew10 308 have 5.06 , ratio on final drive is 15 x 74 = 4.9 or 15 x 76 = 5.1 , anyone got one or anything close ,
Bump , still after if anyone has one
INbox me details on exactly what car to find the correct CWP on and im sure i can sort you something Smile
Team Cyril
Is this to lengthen the final drive for economy gearing?
Isn't there a box from a 206 eco model that does similar?
I should have done this mod previously, doing 2k a month currently...
(26-09-2016, 01:43 PM)Matt-Rallye Wrote: INbox me details on exactly what car to find the correct CWP on and im sure i can sort you something Smile
Pm sent matt
Need to watch out here as some use a diff dia shaft, no issues thou as the 206 Gears fit
(27-09-2016, 09:00 PM)miles Wrote: Need to watch out here as some use a diff dia shaft, no issues thou as the 206 Gears fit
Miles am on close ratio be3 gear set , so don't really want to go changing to 206 gears , thanks wayne
307 will have a be4 like the 206.
(27-09-2016, 09:07 PM)welshpug Wrote: 307 will have a be4 like the 206.
Cheers welshpug , that can be crossed of the list then
Still after a 4.9 cwp for a 5 speed be3 box
bump , still looking for cwp
