	Threads: 42
Car Model/Spec: Astor GTi6 P3
		Everything that could have gone, has gone wrong with my PAS pump relocation.
I've finally moved the pump and it's all connected to the AUX belt, but in the move I connected up the pipe and flex connection wrong. Trying to fix this I've buggered up the pipe connection into the pump.
Does anyone know where I can get an angled after-market connector into the pump, high pressure hose and a connector onto the piping which feeds under the engine block?
Thanks
	Threads: 128
21
	Given 41 thank(s) in 38 post(s)
		itll be one of those "wont leak, just explode" things most likely.  lol
Pirtek or flowcontrol,   pretty much any half decent hydraulic hose supplier will be able to make/supply the required pipes and fittings.
I wouldn't want to be using copper for a second more than I absolutely needed to..  Burst strength of Cu isn't huge at larger diameters hence they more often use steel,
/Toseland
	Threads: 136
11
		Soft copper case hardens aswell
	Threads: 128
21
		that would be the short fatigue life..  its not rated for the pressures so expands and stretches, hardens, then bursts..
you can have it last months or even years,  or days.   Thinner lines (such as brake lines) have max operating pressures much lower than hydraulic lines,  also the thinner the hose in relation to the sidewall thickness is allow it to sustain for longer periods higher pressures.
the ratio is quite low in normal copper pipe (large diameter vs thin wall) which means that huge forces can be exerted on the sidewalls which physically aren't strong enough to handle it.  Power steering pumps can put out anywhere between 350psi to over 2500 (we had one at work powering a small bench press and it would pop rams not rated appropriately when run with a 1hp motor) it depends, also, where the relief is set and I don't know what that is in the 306. Bear in mind that hitting potholes and bumps can also spike the pressure into the thousands even if the pump doesn't do it normally
/Toseland
