laptop & pc repair
I've a couple of Dell's that I want to repair, one of each.
is there anyone who can guide me through it, Parts etc, or, if close enough, do it for me for beer-chits?
Laptop (Intel i5) req's motherboard & HDD + Win7 & BIOS
PC (Pentium Quad) req's HDD & o/s.
Hate Housework!
depends what the issue is with them?
they gave up the ghost. pc diagnosed as 'failing' HDD. laptop may have also had ransomware Huh
just want to source the correct part nums/parts, & re-install o/s
Hate Housework!
Any hdd will fit as long as it is the same connection, you will have to peer inside the of to find out if it is IDE (seriously old) or sata
There are 2 types of power 4 pin sata and 7 pin sata. 4 pin is older, just disconnect the cables to the hdd to find out, replacements are dead cheap.
With the laptop get a CD of the operating system and as long as you still have the sticker for Windows with ledgiable numbers, do a fresh install.
Simply put the cd in and follow the instructions on screen. I could have both done in about 3 hours as Windows takes about 2 to do fully.
If you do re-install Windows, it will at some point as where you want to install it, choose to delete partitions and format, this will remove all data from the HDD and be like new.
Not always Grumpy!!
306 Cabby SE, 2.0l 16v
switch the hdd to a solid state one, but you will need a 3 inch bay adapter
More than happy to do this for you.
Let me know if/when Smile
i'll prob take you up on that ruan.
will contact Dell to see what the part num is for the laptop m/board.
Hate Housework!
Yeh fit a new hard drive and then reinstall windows. Easy Smile
that's the tower sorted then =D
Hate Housework!
(21-05-2016, 06:42 PM)Magenta Sunset Wrote: i'll prob take you up on that ruan.
No problem!
What's up with it? Won't power on anymore etc? Or random crashing...
Bet I have a fix for it, slightly unorthadox, but might be worth a try... Can't be any worse than it is now...
tower just needs HDD's
laptop iirc fried/goosed m/b + new HDD.
old HDD's professionally terminated.
Hate Housework!
I bet it's a classic problem that the BGA soldered CPU with lead-free solder has cracked due to heat cycling and needs reflowing.
Mainboard out and bang it in the oven at 180*C for a bit.
It's worth a shot as you can't make it any worse.
lol Xbox style repair
GTI6 Info
knowing my oven, it'll melt into a gooey mess. (absent minded here)
the main thing for me, is it's a rare factory red one, almost the some shade as my Diablo Big Grin
Hate Housework!
(21-05-2016, 08:13 PM)Magenta Sunset Wrote: the main thing for me, is it's a rare factory red one, almost the some shade as my Diablo Big Grin
An older dell xps m1530???
Then if the mobo is broken it is likely to be the GPU, fix as per Ruans instructions! (let him do it!)
Pretty much the same issue for 90% of laptops from the same era, cpu, gpu, nb, all using lead free shitty solder and they crack... A reflow in the oven usually fixes it Smile
Inspiroin 15R N5010 - I think
Ruan, you're welcome to have a go. ThumbsUp
Hate Housework!
