Finally got it plugged in
#61
Everyone except welshpug...he 'corrects' it every time it comes up... Rolleyes
Yeah it does come up, iirc there's 2 types of BSI, the above mentioned one being the 'better'. But yeah everyone even auto electricians and ProSteve even know it as a BSI. It's debates like that, which cause confusion for people!
good news...so its staying in your possession?
Certainly is, I was going to fix it and sell it but I'm thinking twice now it's running.
(03-03-2016, 09:04 AM)aaron_one Wrote: Yeah it does come up, iirc there's 2 types of BSI, the above mentioned one being the 'better'. But yeah everyone even auto electricians and ProSteve even know it as a BSI. It's debates like that, which cause confusion for people!
I might start kicking off every time somebody calls a Rzeppa joint a cv joint because it's not the precisely correct technical term. Or i could continue having a life, hmmm.... Wink
Or a lamp, a bulb?
lol
(03-03-2016, 07:42 PM)Piggy Wrote: Or a lamp, a bulb?
lol
Let's not start that one... lmao
Piggy? is that you? oh wait. you actually know what you're talking about in the first place!
/Toseland
You say that, Ruan rightly pointed out earlier that 306s don't use Rzeppa joints. Rofl
Surely, in the interest of being anal, an rzeppa is still a TYPE of constant velocity joint...
/Toseland
They are constant velocity joints...as said, rzeppa is just a type of one.
But... I did always think that rzeppa design cv's were used? At least the outer two?
I mean they aint bendix-weiss are they?!
No, they are the ball and grove type, but a slimmed down version.. in principle still rzeppa but with 3 balls instead of 6. Cheap bastards
/Toseland
I thought they were 6 balls?! Lol
I pulled my nackered one apart.. the same as the Rzeppa in principle but with half the bearings, so it still works but not quite as smooth and weaker.. not a huge issue on that though as the breaking point will unlikely to be found on most cars and this certainly wouldn't be the weakest point of the drivetrain by a long shot.
/Toseland
Forgot about this one, glad you got it running. Texton box on the 306s, BSI on everything else. It's the same thing, just the box which links the immobiliser to the engine ECU.
Glad you got it running, and good to see I was right on the BSI front too Wink
HDI Tuning Ltd
www.hdi-tuning.co.uk
is there a guide or instructions for pp on here anywheres, its loaded on the laptop and seems to work, but before i connect it to the car, i would like some instructions. or do i follow the on screen prompts??
also where is the build code on the car? 306 2l hdi ph3 estate 1999
PP2000 Guide
There you go
Behind the passenger side strut top I believe for the build code.
Thanks given by: pug306driver
#78
thank you thank you thank you!!
     would this be the build code sticker, on the drivers door frame by the door catch??
That's the sticker, 8207 is your build code.
#81
thanks all, will be having fun this weekend after playing with pp first. I have a feeling there may be more questions, but that's for later.
(05-03-2016, 07:50 PM)toseland Wrote: No, they are the ball and grove type, but a slimmed down version.. in principle still rzeppa but with 3 balls instead of 6. Cheap bastards
sounds like a base model el cheapo shaft, anything decent will have a full 6 ball outer CV and a sliding tripod inner
Users browsing this thread: 18 Guest(s)
