	Threads: 170
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
	Threads: 170
		Been a pain messing around with mounts ect but it's in and runs. Just abit more niggly bits and connect pipes ect then done
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 186
38
Car Model/Spec: MG ZR VVC
		Long time no see pal. This going super chronic boost or just enough to make the daily drive a bit more bearable?
	Threads: 170
		Eyup how's it going?  Safe boost for now not finished yet should be by Saturday. Do have big turbo ect already [emoji106]
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 170
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 61
11
		Plan sounds good,can't wait to see it done.
	Threads: 170
		Van is done. Had to change box, clutch, flywheel, timing belt and also move rear fork for lower mount. Now done but not 100% just a few niggly bits left. Also fitted the stereo
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 170
		02-04-2016, 10:51 PM
(This post was last modified: 02-04-2016, 10:51 PM by karl1989.)
Need some wheels now
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 170
Custom sticker
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 38
Car Model/Spec: D'turbo S
		Hi looking good the 1.9D is pretty dead how is it having the DT?
Was it fairly straight forward?
As I've possibly gotta stick a XUD in a belingo multi space and Had a couple questions if I may
Which box did you use?
How did the turbo exhaust elbow work out?
Final don't suppose you have a picture of the lower mount?
	Threads: 170
		Now I know everything yes. Was a pain at the first. Used Xud box with all the Xud mounts. I've got a down pipe of a xantia work fine enough room. As for the lower mount the fork needs to be removed and moved over there is a hole already there just have to drill it too make it abit bigger. What shape is the multispace?
Ph3 perv cab heaven
Black ph1 XUD died
	Threads: 38
		12-04-2016, 08:48 PM
(This post was last modified: 12-04-2016, 08:50 PM by blinkyeatu.)
		ahhh nice one man thats really helpful ill have a look into it.
guess i would call it phase 1 same front end as yours however its gold and gold/green interior :/ absolutely awful
have you or and are you doing a brake and axle upgrade?
	Threads: 170
		Mines the ph2. Not sure on axle upgrade as these axles do well with weight so may leave it
Ph3 perv cab heaven
Black ph1 XUD died
