Been a pain messing around with mounts ect but it's in and runs. Just abit more niggly bits and connect pipes ect then done
Long time no see pal. This going super chronic boost or just enough to make the daily drive a bit more bearable?
Eyup how's it going? Safe boost for now not finished yet should be by Saturday. Do have big turbo ect already [emoji106]
Plan sounds good,can't wait to see it done.
Van is done. Had to change box, clutch, flywheel, timing belt and also move rear fork for lower mount. Now done but not 100% just a few niggly bits left. Also fitted the stereo
Need some wheels now
Custom sticker
Hi looking good the 1.9D is pretty dead how is it having the DT?
Was it fairly straight forward?
As I've possibly gotta stick a XUD in a belingo multi space and Had a couple questions if I may
Which box did you use?
How did the turbo exhaust elbow work out?
Final don't suppose you have a picture of the lower mount?
Now I know everything yes. Was a pain at the first. Used Xud box with all the Xud mounts. I've got a down pipe of a xantia work fine enough room. As for the lower mount the fork needs to be removed and moved over there is a hole already there just have to drill it too make it abit bigger. What shape is the multispace?
ahhh nice one man thats really helpful ill have a look into it.
guess i would call it phase 1 same front end as yours however its gold and gold/green interior :/ absolutely awful
have you or and are you doing a brake and axle upgrade?
Mines the ph2. Not sure on axle upgrade as these axles do well with weight so may leave it
