	Threads: 465
114
Car Model/Spec: Vauxhall
		be careful as technically it will fail its MOT without the abs as the car was built/sold with ABS
	Threads: 127
33
Car Model/Spec: ZX Volcane TD
		id personally run a diagonal split from to rear from the mc
	Threads: 210
1
Car Model/Spec: Ph1 White Gti6/306 DTurbo
	Given 7 thank(s) in 7 post(s)
		Ah okay what's the advantage of doing that
	Threads: 386
87
		18-12-2015, 04:55 PM
(This post was last modified: 18-12-2015, 04:55 PM by Toms306.)
		If you get a split brake pipe you can still brake in a straight line in theory.
	Threads: 206
3
Car Model/Spec: 3dr dt-s
		18-12-2015, 08:32 PM
(This post was last modified: 18-12-2015, 08:36 PM by daddyfixit.)
		1.  i cant see why you would remove a factory-fitted safety feature to fit a "better" air filter ??????  someone has already said its pointless....(filter mounted under bonnet surrounded by warm air)
2.  when the car chassis number goes into mot stations computer it will print out that the car has ABS and it needs testing, so car will fail the mot test.
3.  why not fit a k&n or a green cotton replacement filter in the original airbox and run a cold air feed pipe to the box ?
	Threads: 15
2
Car Model/Spec: XSi
		19-12-2015, 12:58 AM
(This post was last modified: 19-12-2015, 01:07 AM by adam b.)
		More control if you have a bias valve to the rear brakes. Unless you can load compensate then diagonal will lock the rears all the time. This time of year on cold tyres mine does it a lot...
No issues at all on mine for the mot
I prefer it without ABS to be honest. Always felt it kicked in too early. Lots of weight out and it's much easier plumbing in a hydraulic handbrake
P1 XSi track car
2.4 LWB T4
