Threads: 110
20
Looks like all the right stuff to me. B4s are pretty much just standard struts i believe but being brand new you should fell an improvement. As your doing the springs and struts i would consider doing the top mounts and bearings as well as your going to all the effort.
On the axle i think there is mixed reviews on IMaxle, does seem pretty cheap. I personally haven't had anything to do with them though
Threads: 58
ive done nothing but rectify im axles work lately, cheap chinnese parts, poor build quality from wrong bolts to silly mistakes like once side higher than other! personally avoid!!
Threads: 186
6
Car Model/Spec: Peugeot 306 2.0 HDI
I was going to go with them as they do fitting as well and I don't have the space/tools to do the work my self tbf haha
Threads: 15
Car Model/Spec: XSi
Don't get b4s, either buy Peugeot new or b6. They aren't at all good imo
P1 XSi track car
2.4 LWB T4
Threads: 186
6
They are a lot more pricey than the B4's though and most people seem to have suggested that the B4's are really good for standard style shocks.
I'm looking at these kits and wondering how a set of dampers for a 306 can work for a 1.4 petrol as well as a 2.0 diesel. The weight difference is massive :S
Threads: 15
Car Model/Spec: XSi
That's fine but the last two sets I've had were crap. The proper standard dampers are very good
P1 XSi track car
2.4 LWB T4
Threads: 186
6
Fair enough. How much were the proper standard ones do you know?
I suppose I could get standard shocks and eibach springs. Then lower the rear axle.
I thought the rear axle was knackered tbf but looking at it one of the shocks is a lot more compressed than the other indicating that the shock has collapsed. If this is the case then the reason I have camber on the other side is because its leaning in because the right is lower from the dead shocker hopefully
Threads: 18
10
Have Bilstein changed the B4's recently then? Historically they used to be the best of the non-OE replacement
standard shocks, but the comments above suggest that's no longer the case
