Threads: 110
20
Im looking to put a rev gauge in a 205. Going to get an after market 1 like this http://www.ebay.co.uk/itm/281835532818?_...EBIDX%3AIT
Whats the best way to go about wiring them up? Would i be able to do any thing with the original flywheel sensor to make it work from that?
Threads: 136
11
What clocks you got in the 205? Base model ones?
Threads: 110
20
(25-10-2015, 07:21 PM)Paul_13 Wrote: What clocks you got in the 205? Base model ones?
Yeah its just a 1.8 diesel but im putting a 1.9 dt lump in it
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
Have fun with that...
Threads: 110
20
(26-10-2015, 11:56 AM)silverzx Wrote: Have fun with that...
What with getting a rev gauge to work?
Threads: 136
11
You could swap the dash loom (stdt/gti) which serves the clocks and put some STDT clocks in and you'll have a working rev counter.
I've done this myself and I know it works. Straight swap.
You just need a stdt/gti clock surround.
Most of which I conveniently have
Gti clocks could be used, just need to hook up all the sensors. Which is what I'm planning to do.
Rev counter will read to 8 instead of 6 on the gti clocks
Threads: 266
18
(26-10-2015, 01:04 PM)Frosty Wrote: (26-10-2015, 11:56 AM)silverzx Wrote: Have fun with that...
Yeah, looked into it ageeeeeees ago and was more ball ache then it was worth.
So I got STDT Clocks etc and then ended up selling up.
Threads: 18
10
(26-10-2015, 01:16 PM)Paul_13 Wrote: Gti clocks could be used, just need to hook up all the sensors. Which is what I'm planning to do.
I doubt that a standard GTi tacho will work, at least not without modification.
The GTi tacho needs to see the high voltage pulse off an ignition coil to work, and you won't have that from the induction pulse from the TD pickup. Even removing/bypassing the filter circuit like you do when you convert the tacho to work with later engine management or aftermarket ECU's I don't believe will work, evidenced by the fact that XUD's won't work with HDi clocks and vice-versa.
The circuit board on the TD tacho is quite different to the GTi tacho. I've got both at home somewhere.
Threads: 136
11
(26-10-2015, 02:02 PM)silverzx Wrote: (26-10-2015, 01:04 PM)Frosty Wrote: (26-10-2015, 11:56 AM)silverzx Wrote: Have fun with that...
I don't see what's so hard.
All it is
Take dash out
Swap loom like for like
Reinstall dash and put stdt clocks in
The Rev counter sensor was already in the engine and plugged into the loom. Its present just unused
Threads: 266
18
(26-10-2015, 03:07 PM)Paul_13 Wrote: (26-10-2015, 02:02 PM)silverzx Wrote: (26-10-2015, 01:04 PM)Frosty Wrote: (26-10-2015, 11:56 AM)silverzx Wrote: Have fun with that...
All it is
Take dash out
Your missing the point.
I'm saying using the STDT loom/clocks is best option.
Anything else is a ball ache.
Threads: 136
11
Gotcha
Threads: 110
20
I just want an easy option tbh, like the 1 the put in the link on ebay. Just screw that to the dash but how is best to wire it up is my question really?
Threads: 61
Given 6 thank(s) in 5 post(s)
I've heard of some people taking the reading from the 'w' terminal from the alternator
Threads: 266
18
(26-10-2015, 10:30 PM)aggyj17 Wrote: I've heard of some people taking the reading from the 'w' terminal from the alternator
Yeah, Ruan went on about that.
Threads: 19
I tried the 'W' terminal thing. didn't get anywhere. though I might of had a goose'd gauge.
Threads: 110
20
I does say it comes with instructions to get a reading from the alternator i think.
I was hoping someone else had tried fitting an aftermarket rev gauge before but guess no one has
