Gearbox Question
I've seen a few people go from a gti6 box to the 1.8 16v box. To convert it back to 6 speed is it a case of just putting the 6 box back on or do you have to do more than that?
your better off going to the xsara vts 5 speed box, as far as im aware its the case of changing the clutch to a xsara push clutch and possibly the cable too.
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
(16-09-2015, 08:27 AM)Stef205 Wrote: your better off going to the xsara vts 5 speed box, as far as im aware its the case of changing the clutch to a xsara push clutch and possibly the cable too.
The car already has a 5 speed on it but if I was to put the 6 speed gearbox back on would it be a case of just changing the box? Or would the clutch have to be changed as well
youd have to change the clutch.
on a separate note why would you want to stick that box back in its a awful box! Tongue
05' Evo 9 IX GT
Team eaton.
1.8 uses a 200mm push clutch.
gti6 and xsara vts use 215mm pull clutches.
you'd need to swap the clutch arm and bracket, cable, flywheel and clutch.
So may as well keep it a 5 speed then?
Sure it's a 1.8 'box? Not a 2.0 XSi one? Not sure which clutch the XSi's use.
(16-09-2015, 10:14 AM)Toms306 Wrote: Sure it's a 1.8 'box?  Not a 2.0 XSi one?  Not sure which clutch the XSi's use.
That's what I've been told. It's a gti6 and he put the 1.8 16v 5 speed box on it for track use
Probably has all the gti6 clutch arms fitted then.
if you're getting rid of the 1.8 box I may be interested, if you can post the code off it.
(16-09-2015, 11:38 AM)welshpug Wrote: Probably has all the gti6 clutch arms fitted then.
Cool I'll let you know what happens with it Smile
You need to fit the reverse cable as well.
(16-09-2015, 04:26 PM)Niall Wrote: You need to fit the reverse cable as well.
What's your opinion mate. GTi6 with a 5 speed, any good? Or is the 6 speed worth the hassle of reinstalling
  6 gearbox question mackat 18 12,407 26-05-2015, 03:55 PM
Last Post: mackat
