Threads: 45
3
Car Model/Spec: phase 2, stage 2, gti 6.
(28-06-2015, 05:39 PM)welshpug Wrote: "look great and cheap" are really not two things I look for when buying a tyre!!!
Cheap is always good. Comparing them to the big brands they are affordable to the everyman. great, Ihave heard from a mate of mine they stick like shit. Just did a ring trip on them in an sti wrx and recommended them to me.
ie, great and cheap......
Threads: 591
54
Threads: 141
35
29-06-2015, 05:51 PM
(This post was last modified: 29-06-2015, 06:00 PM by ozonehostile.)
(29-06-2015, 07:13 AM)Piggy Wrote: Federal 595 RS-R??
Smallest size they do is 205 in 16"
This is what I'm looking at with the Michelins fully inflated
![[Image: 20150629_132950_zpspar3iowr.jpg]](http://i1310.photobucket.com/albums/s649/ozonehostile/Mobile%20Uploads/20150629_132950_zpspar3iowr.jpg)
Clears by a hairs width but I can see it catching once driving :/
With a 195 tyre the 5mm difference each side should give me ideal fitment and luckily yokohama seem to make decent tyres in the size I need (at a great cost) so looks like I might be on the team dynamics for pugfest since they have decent tyres still while I empty my wallet next payday for some rubber on the compomotives
Threads: 42
28
what spacers and width have you got?
also, don't run it so fecking low
Threads: 541
124
Arch roller, come and borrow mine.
Threads: 591
54
raise the ride height, thus improving the handling and being able to run some decent tyres!?
That and get rid of that lip!!
Threads: 120
35
Car Model/Spec: Rallye/S16 & 175 megane
(29-06-2015, 08:39 PM)Piggy Wrote: raise the ride height, thus improving the handling and being able to run some decent tyres!?
Zakks car handles absolutely spot on exactly the way it is. im sure landrover spec ride height is fine for a pleasure cruise but for some proper handling you need it low, stiff and wide which is exactly what hes got.
![[Image: 17b33c2a-8471-4313-992e-0a4b324cf926_zps2e63812a.jpg]](http://i143.photobucket.com/albums/r143/matt-taylor/17b33c2a-8471-4313-992e-0a4b324cf926_zps2e63812a.jpg)
Team Cyril
Threads: 45
Car Model/Spec: HDi DTurbo 2001(Y) Astor
(30-06-2015, 08:31 AM)Matt-Rallye Wrote: (29-06-2015, 08:39 PM)Piggy Wrote: raise the ride height, thus improving the handling and being able to run some decent tyres!?
low, stiff and wide
Sorry Matt but. Giggity.
Team disASTOR?
Threads: 120
35
(30-06-2015, 09:10 AM)Razorback_Rob Wrote: (30-06-2015, 08:31 AM)Matt-Rallye Wrote: (29-06-2015, 08:39 PM)Piggy Wrote: raise the ride height, thus improving the handling and being able to run some decent tyres!?
low, stiff and wide
 did make myself chuckle whilst typing it  But its true.
Team Cyril
Threads: 42
28
low does not equate "handles fine"
may handle like a go kart yeah, which is fine if you like shit handling vehicles!
Threads: 591
54
agree with welshy here...
Low doesnt mean handling well.
Threads: 0
I agree low is good I bet it handles well is pretty low but with them arches roll sooner rather than later if you treasure your side wall trust me not worth it you can destroy tires in one drive if the edge digs in I would grind out the metal completely and get some small over fenders will look sweeeeeeeeeet too
Threads: 120
35
(30-06-2015, 05:11 PM)welshpug Wrote: low does not equate "handles fine"
(30-06-2015, 05:47 PM)Piggy Wrote: agree with welshy here...
You both crack me up
I know what handles well and what doesn't thanks, its not an irish spec dturbo with cut springs and sat on the bump stops! Its got properly well fettled suspension and truly handles incredibly well on the road! IMO its the perfect height regardless of how it looks.
But i suppose because its not '40mm and cyclones' it cant handle that well
Team Cyril
Threads: 45
01-07-2015, 07:11 AM
(This post was last modified: 01-07-2015, 07:11 AM by Razorback_Rob.)
I completely agree with Matt. It's incredible how this thing handles. Flat everywhere, everything is uprated and that height sits it so perfectly when blasting it about (even in places Mr Rowbötham shouldn't be :p) his TD's sat perfectly but unfortunately with spacers allowing brake clearance he's having to rethink the wheel clearance but I'm confident the tyres he has in his mind will be perfect with no scrub [emoji108]
Team disASTOR?
Threads: 141
35
Lol, don't check the forum for a couple of days and all this happens.
Anyway, if this was a daily being used to go down all manner of shitty commuting roads then yeah 40mm would probably be better but for what I use it for, nice weather, nice roads then I'll stick by the ride height being spot on.
The clearance issues are purely the convex sidewall on the Michelins and now with a set of yokohama tyres priced up in a more suitable size it'll be perfect (hopefully)
But thanks for the input everyone
Threads: 141
35
Threads: 141
35
Some new shinies arrived the other day :
Powerflex black series p and roller bushes, I recently sold my roller bearing bushes not wanting to go too extreme on a predominantly road going car so these seemed a good compromise and completes my powerflex product collection for the 306
Recently since fitting the compomotives ive found that the wheels on the rear drivers side seem to be about a mm closer to the arch than the other side, I've had it tracked and everything lines up fine and the beam is still spot on for camber and toe so I'm puzzled.
One theory I keep coming back to is that there must be some factory tolerance range for beam mounting holes on the shell? And since the original beams are rubber mounted this must mean some sort of give in beam position?
I'm wandering if I'm just noticing it now as I've dropped the ride height to the top of the wheels and solid mounted the beam.
Any thoughts?
Threads: 19
12
Didn't cully have some issue with the beam on his '6 that needed adjustment on the bolts?
I could be wrong there though.
Threads: 141
35
(24-07-2015, 12:53 PM)mr_fish Wrote: Didn't cully have some issue with the beam on his '6 that needed adjustment on the bolts?
Holes in the boot floor needed adjusting? That fits in with my thoughts about factory tolerances
Threads: 102
9
Threads: 19
12
24-07-2015, 02:46 PM
(This post was last modified: 24-07-2015, 02:46 PM by mr_fish.)
(24-07-2015, 02:11 PM)ozonehostile Wrote: (24-07-2015, 12:53 PM)mr_fish Wrote: Didn't cully have some issue with the beam on his '6 that needed adjustment on the bolts?
Think there is a minimal scope to actually adjust the beam on the factory holes. Though, as said, I could be talking utter bollocks. But seem to remember something.
Threads: 141
35
Barely driven this since pugfest lol. I did get around to fitting the power flex wishbone bushes though, will test drive after the mot on Monday
Threads: 141
35
Finally had time to get the tracking sorted properly by my mate who I know will do it properly.
New bushes doing their thing but I'm still puzzled about my rear beam readings.
To me it seems to have a lot of toe in and still have the issue of the one side being slightly closer to the arch than the other but it drives spot on straight and doesn't crab.
Maybe time to rebuild the beam over winter or am I worrying about nothing?
Threads: 465
114
Car Model/Spec: Vauxhall
bent rear stub axle?
yes ive got the same with mine, off side runs closer to the inner arch than the n/side
there is no adjustment on the mount holes to be able to move the beam on the solid mounts
with the 16" rims with the car loaded mine just rubs the o/side arch liner
dont see any problems on the tracking of the rear since i replaced the bent stub axle
Threads: 141
35
(12-09-2015, 12:44 PM)cully Wrote: bent rear stub axle?
Glad I'm not the only one then, I wonder if by solid mounting the beam we've met the extremes of the factory tolerance that would be taken out by the oem rubber mounts? Lowering also probably highlights the issue by being closer to the arches
Guess there isn't a huge amount I can do about it, it drives spot on so guess that's good enough
Threads: 42
28
the beams will shift a bit if you slacken the bolts and lever it about.
Threads: 465
114
(12-09-2015, 01:35 PM)welshpug Wrote: the beams will shift a bit if you slacken the bolts and lever it about.
mine wont as i have tried
Threads: 42
28
Threads: 465
114
lol maybe slot the fixing holes first
Threads: 141
35
couple of updates:
firstly in the month I was using this as my daily on an 80 mile commute the rear shocks died whilst overtaking a car leading to some very clenched moments as the rear end started to get a bit loose. On further inspection it seems the shocks over compressed and lost pressure. Going to upgrade to some b8's or better whilst its off the road for winter.
And on the subject of off the road for winter, I have everything i need to finally fit some more throttle butterflies
watch this space, but shhhh don't let the mrs know
