Threads: 371
29
Car Model/Spec: ford fiesta
16-08-2015, 08:10 PM
(This post was last modified: 16-08-2015, 08:13 PM by bashbarnard.)
Ever since i started back with the xud engine after a long break i seem to have become addicted to the "just a bit more" "one more psi" and my latest what happens if i do this to a bosch pump? I now have 5 pumps.
Anyone else get like this.
Lost count. I have 6. Shit.
Threads: 476
81
Car Model/Spec: 306 Rallye
yeh with the 1.8 im constantly turning up the boost. It makes so much power but i just crave more.
Threads: 591
54
It's more...
One more psi...phew it didnt blow up... One more psi... Phew it didnt blow up... Repeat
Threads: 186
38
Car Model/Spec: MG ZR VVC
Given 21 thank(s) in 19 post(s)
Im the same, always trying to get just one more psi..although it's normally compression rather than boost
Threads: 386
87
(16-08-2015, 08:32 PM)Piggy Wrote: It's more...
To what end...? Eventually it will blow up...
Tbh this is what I dislike about modding, it's never enough, everytime you change something it's better for a week or two...then you want more again... Until eventually you start breaking stuff.
Threads: 61
3
Car Model/Spec: Phase 1 306 xsS
Given 21 thank(s) in 21 post(s)
Did you pick up those 2 pumps then?
Threads: 128
21
Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
Given 41 thank(s) in 38 post(s)
17-08-2015, 01:07 AM
(This post was last modified: 17-08-2015, 01:16 AM by toseland.)
tuning should be done in this order for an XUD
more fuel, more boost, cold air inlet, more fuel and boost again, cook head, get head skimmed, new HG, refit, fit EGT gauge, more fuel more boost, cook head second time, fit intercooler, more boost and fuel, bigger turbo more boost, snap rod, new engine bigger intercooler 11mm pump, forged rods, second turbo, lift head, rebuild with ARP bolts...........
tuning order for an MG..
more bfuel, replace headgasket, new air filter, replace headgasket, investigate low compression problems, replace headgasket, investigate electirics problems, replace headgasket, start car, replace headgasket, inflate tyres, replace headgasket
/Toseland
Threads: 448
51
I'm like it with my tyres. Just one more psi...
Threads: 371
29
(17-08-2015, 12:44 AM)Redordead89 Wrote: Did you pick up those 2 pumps then?
I won them on ebay and will be picking them up this week. Need to get rebuilding and selling!! I want to keep a couple spare as test pumps though.
Threads: 85
8
Car Model/Spec: E90 330i
Given 15 thank(s) in 15 post(s)
(17-08-2015, 01:07 AM)toseland Wrote: tuning order for an MG..
Threads: 186
38
I'd be mad if I wasn't doing the headgasket right now
Threads: 120
35
Car Model/Spec: Rallye/S16 & 175 megane
Given 40 thank(s) in 40 post(s)
(17-08-2015, 06:17 AM)Iceman299 Wrote: (17-08-2015, 01:07 AM)toseland Wrote: tuning order for an MG..
(17-08-2015, 11:30 AM)lolsteve Wrote: I'd be mad if I wasn't doing the headgasket right now
Im the same but with handling. Always thinking 'hmm just some stiffer springs... hmm maybe if i widen the front track just 20mm... maybe run some slightly wider tyres. right now i need bigger brakes'
![[Image: 17b33c2a-8471-4313-992e-0a4b324cf926_zps2e63812a.jpg]](http://i143.photobucket.com/albums/r143/matt-taylor/17b33c2a-8471-4313-992e-0a4b324cf926_zps2e63812a.jpg)
Team Cyril
