87 Location: Suffolk
		And maybe four candles....'andles for fowks...
 But seriously, I didn't realise the quality of garden hoses varied so much!  Bought a Hozelock 'starter' hose today, as I already had a pressure washer but was borrowing parents hose before.  And, well, it's shit.  I knew 'starter' meant it wasn't top of the range, but what's the point of a hose that kinks at every opportunity and collapses under it's own weight?  It's also impossible to roll up neatly or unroll without causing a huge tangled mess.  My own naiveity I guess, doubt it can be returned to the shop so may have to cut my losses there.
 So question is, which ones are the best value for money?  I don't mind spending a bit more on one that isn't just going to cause constant hassle!
 Cheers
 Tom
	Threads: 42
28 Thanks: 3Given 89 thank(s) in 88 post(s)
		buy a reel for it, or bolt an old alloy to the wall of the house.
		Tried an old reel from Nans...it collapses under its own weight so you have to unwind the whole thing first...then it kinks everywhere!     Literally not used a hose this bad before.
	Threads: 57
3 Location: Peterborough
 Car Model/Spec: 306 s16 406 v6 Saab 93 Ttid
 Thanks: 1Given 3 thank(s) in 3 post(s)
		Never had a problem with them
 Even an expensive hoselock will kink if it's not laid out right
 Failrly sure the starter set is more to do with the accessories included rather than hose quality
	Threads: 85
8 Location: Walsall
 Car Model/Spec: E90 330i
 Thanks: 30Given 15 thank(s) in 15 post(s)
		What about those "magic' hosepipes i've seen where they just shrink when not in use and expand when in use. Cant remember what they're called but most likely it's JML related, what isn't?? Lol
	Threads: 47
14 Location: Browsing eBay for Turbos.
 Car Model/Spec: Ford cougar v6.  Mk6 Transit
 Thanks: 12Given 20 thank(s) in 20 post(s)
		All the same IMHO. Don't believe the hype. Any hose on a reel will need fully unwinding before use.  The in feed kinks as soon as you turn the handle.
 Hozelock are generally regarded as half decent/decent anyway.
                                             ![[Image: 2ljm03k.jpg]](http://i57.tinypic.com/2ljm03k.jpg)
        I Don't Have A 306.
	Threads: 27
8 Location: .
 Car Model/Spec: PEUGEOT 308 FELINE
 Thanks: 0Given 5 thank(s) in 5 post(s)
		Hey Tom
I bought this one from john lewis and its good .
http://www.johnlewis.com/hozelock-compac...m/p1694898
		 (25-07-2015, 05:54 PM)swampy Wrote:  Never had a problem with them
I had assumed that's what 'starter' meant as well, it doesn't though, its the crappy hose itself, you can get a 'starter' with varying accessories.  http://www.hozelock.com/watering/hoses.html
I've used hoses at home and at Nans without these constant kinks.  You can't lay this down at all without it kinking let alone move it.
  (25-07-2015, 05:58 PM)Iceman299 Wrote:  What about those "magic' hosepipes i've seen where they just shrink when not in use and expand when in use. Cant remember what they're called but most likely it's JML related, what isn't?? Lol
Not sure I've seen those?  I used to have a 'spring' style one but that's no where near long enough for use here.
  (25-07-2015, 05:59 PM)Danny Wideboy Wrote:  All the same IMHO. Don't believe the hype. Any hose on a reel will need fully unwinding before use.  The in feed kinks as soon as you turn the handle.
Not in my experience, Nans hose is on a reel and I don't think it's ever been fully unwound lol.  Has had a lot of use as well for watering the garden for several years.  Only issue with it now is leaks from the attachments, hose itself is still perfect, I don't know what level of quality it is though.
  (25-07-2015, 06:19 PM)Herby7 Wrote:  Hey Tom
Hmm, it doesn't say which hose comes with that, I'm guessing it was a better quality one though!
Also lol at the review on there, how hard can it be to put together!
	Threads: 465
114 Location: Cullompton Devon
 Car Model/Spec: Vauxhall
     Thanks: 1Given 98 thank(s) in 92 post(s)
		always unroll it dont loop it off the role or it will always spiral and tristwind it up with water pressure in it to prevent it kinking
 never had a problem with the hoses i buy
	Threads: 47
		Honestly Tom .Being a builder we use hoses all the time to fill water butts n stuff. Many people have many expensive different solutions for hosepipes but they are generally not much difference from one to another.
 Generally if it is wound and unwound correctly it should be fine but always best to unwind it all to make sure there's no kinks.
 Maybe your water pressure is no good?
        I Don't Have A 306.
	Threads: 85
8 Location: Walsall
		25-07-2015, 08:38 PM
(This post was last modified: 25-07-2015, 08:39 PM by Iceman299.)
		This is what i was on about, Tom. 50ft hose weighs 1lb! Lolhttp://www.argos.co.uk/static/Product/pa...069143.htm
	Threads: 0
45 Thanks: 177Given 28 thank(s) in 28 post(s)
		We've got 200ft of hose on a reel & I use probably 25ft when doing the car, never had any issue of it collapsing. What's your pressure like?
 Ps those magic hoses are rubbish, they don't last long at all.
		 (25-07-2015, 08:38 PM)Iceman299 Wrote:  This is what i was on about, Tom. 50ft hose weighs 1lb! Lol
That does look awesome tbh!  Steretypical American ad video as well.     (25-07-2015, 08:44 PM)JJ0063 Wrote:  We've got 200ft of hose on a reel & I use probably 25ft when doing the car, never had any issue of it collapsing. What's your pressure like?
Pressure is too good tbh...I've had to turn it down outside after it blew two tap seals.     I'm pretty sure it's just poor quality tbh, as I say I never had the same issue at home or Nans with hoses/reels.
	Threads: 541
124 Location: Aylesbury
 Thanks: 7Given 59 thank(s) in 58 post(s)
		I've got the cheapest longest one tesco do and it's fine.
	Threads: 62
10 Location: Rugby, Warwickshire
 Thanks: 0Given 11 thank(s) in 11 post(s)
		Hozelock kink proof tbh.  That's what I have.
Night Blue VW Golf 7 GTD : Bianca 306 Rallye : Mini Cooper D (The Mrs') ![[Image: wallye-gtd.JPG?raw=1]](https://www.dropbox.com/s/pcxk1pgpaucznvr/wallye-gtd.JPG?raw=1)
HDi Owner for 200k/9 years
	Threads: 61
3 Location: Glasgow
 Car Model/Spec: Phase 1 306 xsS
 Thanks: 20Given 21 thank(s) in 21 post(s)
		With a heading like "o"s I was more hoping for hoes not hose FFS!Hmmmm
	Threads: 169
91 Location: South London
 Thanks: 1Given 1 thank(s) in 1 post(s)
		You can still return it Tom. Just say it is not satisfactory.
![[Image: car-1.jpg]](http://i1117.photobucket.com/albums/k591/grant-306/car-1.jpg)  Member of the 99% warning or you're nothing club
