10-07-2015, 12:02 PM
Think you should stick to Dervs Piggy
106 Track Toy
10-07-2015, 12:05 PM
(10-07-2015, 10:43 AM)Dum-Dum Wrote: In fairness I could of shortened the bolts but it's quicker and easier just to throw a couple of extra nuts on them. That would be awesome mate thanks(10-07-2015, 10:53 AM)Piggy Wrote:(09-07-2015, 05:09 PM)Nathan1305 Wrote:(09-07-2015, 04:48 PM)Stef205 Wrote: WTF is this!! could we not find a shorter bolt?! It is a small filter but doesn't perform to bad it doesn't actually get hot. I'm going to invest in a BMC enclosed unit that way it gets a good air feed and looks awesome
10-07-2015, 12:45 PM
BMC is an overated rip off mate, you dont get enough heatsoak at the front of a 106 engine bay for it to be a problem. spend the money elsewhere and run a cold air feed from the foglight
Also the filter you have is plenty big enough for a 1600cc N/A engine
10-07-2015, 02:20 PM
(10-07-2015, 12:45 PM)Matt-Rallye Wrote: BMC is an overated rip off mate, you dont get enough heatsoak at the front of a 106 engine bay for it to be a problem. spend the money elsewhere and run a cold air feed from the foglight Oh really? Fair enough I'll just look into a cold air feed if that the case. I think tyres are my next thing to tick off the list just has budgets up front and Toyo TR-1 on the rear
Car looks good Nathan
Get some Michelin Pilot Sport 3's on the front, Well worth the money and will be night and day in every aspect from the budgets.
10-07-2015, 02:44 PM
10-07-2015, 02:54 PM
(This post was last modified: 10-07-2015, 02:58 PM by Midnightclub.)
I'd bet PS3's have more grip - plus they'd have grip in the wet too, which let's face it is what the UK is 80% of the time
Check out these two links: http://www.tyrereviews.co.uk/Tyre/Michel...-3-PS3.htm http://www.tyrereviews.co.uk/Tyre/Federal/595RSR.htm
10-07-2015, 03:57 PM
Nathan you have a daily diesel for using in the rain, keep the 106 as a hardcore dry weather only car. and do not skimp on tyres! they are what brings out the best in the supporting modifications.
10-07-2015, 05:07 PM
(10-07-2015, 03:57 PM)Matt-Rallye Wrote: Nathan you have a daily diesel for using in the rain, keep the 106 as a hardcore dry weather only car. and do not skimp on tyres! they are what brings out the best in the supporting modifications. That's why I was looking at the Federals have heard good things about them, I know pebbles rate them quite highly I want this car to be the best it can be so want to experiment with tyre setups
12-07-2015, 07:07 PM
So the car performed perfectly at PugFest. Extremely happy with it. Only thing that was holding it back was the tyres, they didn't appreciate the abuse too well. Managed to bag myself a pretty good deal with the GrpA Baker BM solid rear mounts for £38. They sell their stuff a lot cheaper at shows. So they are ready to go on the new beam
just waiting for my new shocks to turn up then it's ready to go on
12-07-2015, 07:34 PM
have you found a way to mount the 205 washer bottle?
12-07-2015, 07:39 PM
13-07-2015, 08:16 AM
Was this the nana gti that was following a down 'n' out nile 306 estate up the m5 on saturday?
I might be the guy in the diablo hdi that joined you The racestate had all the prescence but this thing sounds the bollocks i love a well breathing TU
13-07-2015, 09:28 AM
(13-07-2015, 08:16 AM)thododd Wrote: Was this the nana gti that was following a down 'n' out nile 306 estate up the m5 on saturday? Haha it certainly was! Yeah that was Ian's (slamwagon) estate. And thanks man do love the sound of this car
13-07-2015, 12:05 PM
(12-07-2015, 07:39 PM)Nathan1305 Wrote:(12-07-2015, 07:34 PM)procta Wrote: have you found a way to mount the 205 washer bottle? make an adapter for it, plug into your car loom and run the bastard down the side, or use the rear washer wiring, with it been the back, so it would be a case of turning the stalk, but you would have to activate the wipers.
13-07-2015, 12:27 PM
(13-07-2015, 12:05 PM)procta Wrote:(12-07-2015, 07:39 PM)Nathan1305 Wrote:(12-07-2015, 07:34 PM)procta Wrote: have you found a way to mount the 205 washer bottle? The wiring is already in place from when it had the washer bag. Just needs extending to reach the rear quarter
14-07-2015, 02:24 PM
(This post was last modified: 14-07-2015, 02:28 PM by Nathan1305.)
My adjustable GAZ shocks arrived today!
so got them fitted to the rear beam. Hoping they give me some decent adjustment and control over the rear end. Tomorrow I'm going to try get hold of a blow torch to burn the rubber beam mounts out and put my solid beam mounts in
14-07-2015, 02:54 PM
Errr don't mean to put a downer on things but there 205/306 items not Saxo/106!
90' 205 gti6 supercharged
05' Evo 9 IX GT Team eaton. Axle rebuilds please contact me for your needs. https://www.facebook.com/axlesbystef/
14-07-2015, 02:55 PM
14-07-2015, 02:58 PM
No 106 units have a spacer on the bottom to space it way from the arm you can see the angle the shock is sat at due to the missing spacer
14-07-2015, 03:10 PM
14-07-2015, 03:41 PM
They certainly look like 306 items I don't have any 106 shocks near me atm but I'll get one later
14-07-2015, 03:44 PM
14-07-2015, 03:48 PM
Nathan in that pic you can clearly see the spacer block stef's saying about that yours dont have!
This piece circled i mean
14-07-2015, 03:55 PM
(This post was last modified: 14-07-2015, 04:17 PM by Nathan1305.)
(14-07-2015, 03:48 PM)Matt-Rallye Wrote: Nathan in that pic you can clearly see the spacer block stef's saying about that yours dont have! Ah I see! Can I not just space mine out with some washers? Or could I even press out that spacer from my old shocks and put them on the GAZ ones
17-07-2015, 08:18 PM
I thought I'd treat the GTi to a good service after its thrashing at Pugfest
got some decent oil, coolant, oil filter, spark plugs, thermostat, sump plug and some gasket sealant for the cam covers as you can't buy the gaskets anymore. Not bad for £53 ECP have a further 15% off using code: Extra15
17-07-2015, 08:42 PM
I would just space the shock out myself personally.
17-07-2015, 08:43 PM
18-07-2015, 06:33 PM
(This post was last modified: 18-07-2015, 06:33 PM by Nathan1305.)
Boredom got the better of me today so I sprayed up the cam covers, pretty happy with the results
it's actually Fiat Broom Yellow but pretty close to sundance.
18-07-2015, 06:48 PM
By pretty close i assume you mean they are both A shade of yellow? Haha
