	Threads: 186
6 Location: UK
 Car Model/Spec: Peugeot 306 2.0 HDI
 Thanks: 29Given 17 thank(s) in 17 post(s)
		Hi all,
 For this summer I am thinking of taking on the daunting task of repairing a 306 hdi air conditioning system. I want my car COOOLLLLDD haha. I have heard they are a right pain in the A** so I am just wondering if anyone has ever actually managed to get one working reliably using new better quality parts and a re-gas?
 What do you guys all think?
 Thanks, Jack
195 Location: Bournemouth
       Thanks: 36Given 82 thank(s) in 78 post(s)
		Yep. 2 years ago, day before FCS. Replaced one of the front pipes with a brand new genuine item and took it to kwikfit for a regas. Was ice cold which was lovely considering it was almost 30 degrees outside
 Did it work the next day when i had to drive 2 hours to fcs in said 30 degree weather? Did it f*ck.
	Threads: 85
8 Location: Walsall
 Car Model/Spec: E90 330i
 Thanks: 30Given 15 thank(s) in 15 post(s)
		 (14-05-2015, 09:22 PM)Niall Wrote:  Yep. 2 years ago, day before FCS. Replaced one of the front pipes with a brand new genuine item and took it to kwikfit for a regas. Was ice cold which was lovely considering it was almost 30 degrees outside
What happened?
	Threads: 186
6 Location: UK
		Haha brilliant lol. I actually want to get to the bottom of what causes them to stop working tbf haha
		 (14-05-2015, 09:24 PM)Iceman299 Wrote:   (14-05-2015, 09:22 PM)Niall Wrote:  Yep. 2 years ago, day before FCS. Replaced one of the front pipes with a brand new genuine item and took it to kwikfit for a regas. Was ice cold which was lovely considering it was almost 30 degrees outside
 What happened?
Dont know. Ripped it out shortly after in favour of boost. I would imagine there was either another leak somewhere on a pipe or the seals had just dried up seeing as it had been empty for so long
Issue is, to repair it and keep it reliable, you need to replace the front pipes (the known original issue causing them all the fail),  most seals and the receiver drier. It all adds up!
	Threads: 15
2 Location: prescott hill
 Car Model/Spec: XSi
 Thanks: 2Given 18 thank(s) in 17 post(s)
		No. The end.
P1 XSi track car2.4 LWB T4
	Threads: 465
114 Location: Cullompton Devon
 Car Model/Spec: Vauxhall
     Thanks: 1Given 98 thank(s) in 92 post(s)
		my estate had working air con when i sold it
i had it repaired under warentee when i bought it    new front condenser and lower front pipe and a regas fixed it apparently
must admit it was nice and cold
	Threads: 85
8 Location: Walsall
		My 306 has always had working a/c. One i had for a few weeks last year had new pipes etc repaired by the previous owner
	Threads: 186
6 Location: UK
		It does seem to sound like it's just a condenser and a set of front pipes so don't see why I wouldn't be able to do it tbf haha
	Threads: 30
5 Location: Birmingham
 Car Model/Spec: 306 HDi Dturbo 5dr
 Thanks: 11Given 17 thank(s) in 17 post(s)
 Country:
		15-05-2015, 05:59 AM
(This post was last modified: 15-05-2015, 06:00 AM by highwayman306.)
		Condenser is situated right at the front of the car and gets peppered with stones from the road. Bad design really so it wouldn't be long before its fubard again    I might ditch my ac and save some weight/fuel...as it uses fuel when it is working anyway and weighs a fair amount which adds to consumption when not in use/working...all in all:
expensive to repair and replace and uses more fuel...
![[Image: 9fa12c59-0c3d-4413-968d-6a7840ff068f.jpg]](http://i693.photobucket.com/albums/vv295/highwayman306/9fa12c59-0c3d-4413-968d-6a7840ff068f.jpg)
	Threads: 202
58 Location: Eastleigh
 Thanks: 2Given 29 thank(s) in 28 post(s)
		 (15-05-2015, 05:03 AM)JTaylor2005 Wrote:  It does seem to sound like it's just a condenser and a set of front pipes so don't see why I wouldn't be able to do it tbf haha
You'll need a receiver drier and I'd imagine the seals will need replacing too.
Are you actually taking on what's been said? As Niall has already explained the above to you.. Tell you what, just change the condenser and front pipes then you can come back and be really surprised when it doesn't work/leaks R134a refrigerant everywhere, which BTW will give you serious frost burn if it gets on your skin.
	Threads: 70
10 Location: Bedford
 Car Model/Spec: HDi Estate
 Thanks: 4Given 9 thank(s) in 9 post(s)
		I got mine working with just a condenser, drier, and new seals, no front pipes needed, still works 12+months later. All cheap enough through eBay.
 Definitely worth fixing!
87 Location: Suffolk
		Got mine working 5 years ago with just a regas....  Back then the phrase 'it only needs a regas' wasn't always bullshit...     Worked for the remainder of my ownership as well (nearly a year!).
However these days I wouldn't expect it to be that easy lol.
	Threads: 186
6 Location: UK
		See it does seem to be hit and miss really. Some people can get it to work some not. Just really like my cold cars so maybe worth having a look into in the future. Maybe improve on it by putting stuff in the way of the rad so it doesn't get mashed again etc.
		Blocking the rad would reduce the cooling, defeating the object.  It's not too bad a location on 306s, the fan infront does shield it a bit.  On the Focus the AC rad is right at the front, fan at the back so gets battered by stones and shit.
	Threads: 136
11 Location: Basingstoke/Reading
 Thanks: 6Given 39 thank(s) in 39 post(s)
		I had working AC before some **** crashed into the front of it loved it having a cold car
	Threads: 2
3 Location: London
 Car Model/Spec: HDI DTurbo
 Thanks: 2Given 0 thank(s) in 0 post(s)
		16-05-2015, 10:00 AM
(This post was last modified: 16-05-2015, 10:05 AM by Ican.)
		I fixed mine link to thread. http://306oc.co.uk/forum/showthread.php?...#pid304190
Just to add its still working today without needing a regas so the repair was a good one.
	Threads: 26
0 Thanks: 1Given 1 thank(s) in 1 post(s)
		I fixed mine. New front pipes, condenser, receiver/drier. But then the spring clip under the fuel pipe was broken, so used some cable ties and clips to hold together. Was working fine last time I saw my car. Sent it to get some interior refinished and for various reasons I've not seen it for a few months!
	Threads: 102
18 Location: Warwickshire
 Thanks: 0Given 22 thank(s) in 22 post(s)
		Was just about to say MisterGTR had fixed his but he's here already!
	Threads: 10
 Car Model/Spec: Meridian 1.9TD
 Thanks: 0Given 1 thank(s) in 1 post(s)
		I fixed mine by putting a new condenser on when I first got the car 4 years ago and it's still cold.
	Threads: 186
6 Location: UK
		Okie dokie so it is possible. It may be worth just trying a regas first then and seeing how that goes. I have been told its probably not going to last long and by the sounds of it that's very true haha. You never know I might get lucky and it may last the summer. If not then I will investigate I suppose. Start with a leak test. Where does them? Just find a nearby garage that can do them do you reckon?
Also thats a great write up mark    thanks for posting that.
	Threads: 34
8 Thanks: 0Given 8 thank(s) in 8 post(s)
		Any place that does a/c will do a test first
	Threads: 2
3 Location: London
		16-05-2015, 03:24 PM
(This post was last modified: 16-05-2015, 03:34 PM by Ican.)
	Threads: 8
0 Thanks: 0Given 1 thank(s) in 1 post(s)
		16-05-2015, 07:32 PM
(This post was last modified: 16-05-2015, 07:34 PM by Pgtips.
 Edit Reason: Additional info
		 (16-05-2015, 03:24 PM)Ican Wrote:  Save  a bit of money http://m.groupon.co.uk/deals/premium/ats...r/62021291
Wonder if they still charge if they find a leak
(Pressure check will take up to an hour; if a leak in the air conditioning system is detected, the recharge and treatment will not proceed)
	Threads: 26
		17-05-2015, 12:20 AM
(This post was last modified: 17-05-2015, 12:21 AM by MisterGTR.)
		Go to kwikfit. They only charge if they can charge your AC. So first time I went after doing all the replacement work, they told me that they couldn't charge the system and actually pointed out the issue with the spring clip ie where the leak was. Which I bodged and got working.
	Threads: 9
 Car Model/Spec: 306 2.0 HDi D turbo
 Thanks: 1Given 0 thank(s) in 0 post(s)
		The A/C in my xsara works perfect, the 306 doesn't. That could be due to the missing A/C rad... Do Peugeot still sell the parts or do I need to visit the scrappies?
	Threads: 26
		 (19-05-2015, 02:24 PM)Will Wrote:  The A/C in my xsara works perfect, the 306 doesn't. That could be due to the missing A/C rad... Do Peugeot still sell the parts or do I need to visit the scrappies?
 I bought a Nissens one off eBay.
2 Location: Reading
 Car Model/Spec: BMW 330Ci/VW Up/205GTi/205Mi16
 Thanks: 0Given 5 thank(s) in 5 post(s)
		Mine has just given up after a regas a few weeks ago (whole point of the regas was to find the leak, it's really small apparently).
 Got a set of new front pipes, a new dryer and new condenser ready to go on. Pretty much why my FMIC hasn't been fitted yet. Want to sort this first. Got the Dryer and Condenser off Amazon of all places, under £100 for both and they're Valeo.
2001 BMW 330Ci2012 VW High Up
 1988 205 GTi 1.6
 1990 205 Mi16
	Threads: 11
0 Location: West midlands
 Car Model/Spec: 306 HDI Stage 2
 Thanks: 1Given 8 thank(s) in 8 post(s)
		We're did you buy new front pipes from?
2 Location: Reading
		 (20-05-2015, 02:35 PM)Alan_M Wrote:  Mine has just given up after a regas a few weeks ago (whole point of the regas was to find the leak, it's really small apparently).
Just got back from the garage, and whilst there is no sign of the dye, there is a lot of dampness in the corner of the condenser.
Next step is to replace condenser & dryer, and probably new front pipes too. The A/C was great when it worked, and sorely missed over the last few days. I plan on keeping the car for a good few years, so don't mind chucking a few quid at it to have the little luxuries working properly.
Big UP  to CitroeMech in Wokingham, who re-gased the car and sent me on my way a few weeks ago, didn't charge me today for hunting down the leak.
 1988 205 GTi 1.6
 1990 205 Mi16
