Amp help!!
Amp help!!
My current amp worked before I swapped it for a second hand amp, the second hand amp and now my original amp doesn't work! I have checked all fuses and connections and they're ok...I'm stumped!
I've even disconnected the battery so the stereo can reset its self Sad
[Image: siggy1.jpg]
Has it got a good earth connection?
Yeah, like I said it worked perfectly until I swapped amps, now neither amp works Sad
[Image: siggy1.jpg]
Could possibly be the remote wire from the head unit, try bridging the +'ve to the remote and if the amp works then you know it's the remote causing the problem
I hadn't thought of that fella Smile...I was thinking about ripping it all out and starting again with new cables, hopefully the amp works Smile
[Image: siggy1.jpg]
