Amp help!! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: Amp help!! (/showthread.php?tid=2404) |
Amp help!! - devils_fuel - 24-03-2012 My current amp worked before I swapped it for a second hand amp, the second hand amp and now my original amp doesn't work! I have checked all fuses and connections and they're ok...I'm stumped! I've even disconnected the battery so the stereo can reset its self
Amp help!! - MarkTD - 24-03-2012 Has it got a good earth connection? Re: Amp help!! - devils_fuel - 24-03-2012 Yeah, like I said it worked perfectly until I swapped amps, now neither amp works
Re: Amp help!! - Midnightclub - 24-03-2012 Could possibly be the remote wire from the head unit, try bridging the +'ve to the remote and if the amp works then you know it's the remote causing the problem Re: Amp help!! - devils_fuel - 24-03-2012 I hadn't thought of that fella ...I was thinking about ripping it all out and starting again with new cables, hopefully the amp works
