	Threads: 24
Car Model/Spec: Cherry Red PH1 306 Dturbo
		Just out of curiosity, My car just got a new water pump and belt, system also flushed. I also replaced the thermostat. It runs now at 83C normal driving with the new thermostat but when I sit parked for 10 mins it rises to 90C. My old thermostat sits at 79 driving but rises to 85 - 90C when sitting for a bit also. I've heard others are sitting at 75C and going to 80 - 85 Max.  Is mine normal ? Ps my rad has a slight hole in the middle (New one on its way)
What does yours run at ?
	Threads: 87
48
		They all go up to 92 the back down when stood in traffic, mine runs at just under 80, have git a nice nissans alloy rad on her though.
	Threads: 30
		80 or just under is normal running temp sure the fans kick in at 95 but I might be wrong
	Threads: 87
48
		 (17-02-2015, 09:56 PM)Dale Wrote:  80 or just under is normal running temp sure the fans kick in at 95 but I might be wrong
no it's not 95, 92 or 93 they kick in
	Threads: 14
Car Model/Spec: 306 meridian d turbo
		Lucky if mine even gets to 70 even when sitting in traffic in the 3 weeks I have owned it has gone above 70 twice
Old enough to know better
Young enough to do it anyway
wishes he had started a rescue project thread
	Threads: 87
48
		 (18-02-2015, 04:11 PM)sb194114 Wrote:  Lucky if mine even gets to 70 even when sitting in traffic in the 3 weeks I have owned it has gone above 70 twice
that means you need to change the thermostat then mate, have you bled your coolant properly yet btw?
	Threads: 14
7
	Given 5 thank(s) in 5 post(s)
		My last one operated around 70ish, pretty sure the previous owner removed the thermostat for some reason.
Never bothered to check tho, always ran like a dream.
	Threads: 14
		Matt I did so yesterday wasn't as hard as I thought running nicely now
