Threads: 26
When its off a cylinder it'll make a sound like that.
Threads: 15
Right guys, I have changed all glow plugs and still the same. I have narrowed it down to cylinder number 1 by unplugging the injector leads one by one. When I did all others the was a very noticeable difference but when I unplugged number 1 there was no difference.
I have Listened to the injectors and I can hear them all ticking very clearly.
So I'm thinking its something to do with the coils or leads. Is there any way to test the coils separately . its the stupid 1 coil each sparkplug I think and has that stupid metal part all across the plugs.
Swap the coils between 1 and 2, start up and remove the plug off of coil two. If theres no difference, you need a new coil. If theres no difference when you take coil 1 off, you have a issue else where
Threads: 23
Car Model/Spec: High Boost Rallye
I'm guessing it hasn't got individual coil packs, and it's just one unit?
Threads: 15
I have no idea. Its a enclosed unit on top of the sparkplugs with just 1 cable plugged in. What happened to just having some ht leads
Threads: 23
Which engine is it, the 138bhp?
Threads: 23
The part number for it is 5970 98
Threads: 15
Right so cleared codes and they haven't come back. Swapped injectors around but still when I unplug injector 1 the engine doesn't change but when I unplug any other injector there is a dramatic change. Checked coil and there is spark on every plug. Changed plugs. I'm not 100% it's misfiring because it doesn't sound too bad now, baring in mind there is a loud exhaust on. But it must be if there's no difference when I unplug number 1 injector, correct? Any ideas at all?
