307 problems
307 problems
So as I say I haven't been on for a while as I got rid of my brilliant 306 Sad anyway I have a 307 2.0 petrol which has developed a problem.
When I accelerate the exhaust has a gurgling sound to it, just like a subaru tbh. Now that would be ok although I also have a loss of power, seems like it's not running on all cylinders, but why the noise? Something to mention is I already have a loud exhaust on but didn't sound anything like it did now.
Thanks in advance.
When its off a cylinder it'll make a sound like that.
Yeah, what he said.
Fix your misfire ThumbsUp
Cheers guys
Right guys, I have changed all glow plugs and still the same. I have narrowed it down to cylinder number 1 by unplugging the injector leads one by one. When I did all others the was a very noticeable difference but when I unplugged number 1 there was no difference.
I have Listened to the injectors and I can hear them all ticking very clearly.
So I'm thinking its something to do with the coils or leads. Is there any way to test the coils separately . its the stupid 1 coil each sparkplug I think and has that stupid metal part all across the plugs.
Swap the coils between 1 and 2, start up and remove the plug off of coil two. If theres no difference, you need a new coil. If theres no difference when you take coil 1 off, you have a issue else where
There is only 1 connector that goes to the long piece that had all the leads that go over the plugs. Is hard to explain. I don't know how to do it Sad
Anyone?
I'm guessing it hasn't got individual coil packs, and it's just one unit?
I have no idea. Its a enclosed unit on top of the sparkplugs with just 1 cable plugged in. What happened to just having some ht leads
Which engine is it, the 138bhp?
Yes mate.
The part number for it is 5970 98
Thanks
No problem.
Right I have u plugged all Injector 1 at a time and when I unplug number 1 nothing changes. Now I have got hold of a diagnostic tool and I have the fault codes on all cylinder apart from 1. Very confused. Thought it's maybe from unplugging them but when I clear they come back. Any ideas? [Image: 6a6642aae5bcac9042f7a733ddd3e08e.jpg]
Right so cleared codes and they haven't come back. Swapped injectors around but still when I unplug injector 1 the engine doesn't change but when I unplug any other injector there is a dramatic change. Checked coil and there is spark on every plug. Changed plugs. I'm not 100% it's misfiring because it doesn't sound too bad now, baring in mind there is a loud exhaust on. But it must be if there's no difference when I unplug number 1 injector, correct? Any ideas at all?
