17-12-2014, 05:11 PM
bonnet could be replaced with a fibreglass unit, if there is a one for these cars.
106 Track Toy
17-12-2014, 05:12 PM
You can buy flat sheets of carbon fibre online, they aren't cheap but for std. rectangular sheets they aren't ridiculous I suppose.
These could then be cut out to make carbon fibre doorcars.
17-12-2014, 05:21 PM
Strip that door properly...
![]() Then start in the back...
Matt-Rallye Wrote:Norledge for prime minister. Poodle Wrote:I reckon Norledge has got it on the head mind. Matt-Rallye Wrote:Norledge gets my vote tbh.
17-12-2014, 05:34 PM
17-12-2014, 06:20 PM
(17-12-2014, 05:04 PM)Piggy Wrote: Bonnet too can be 'thinned out'. Yeah I'm going to look into that at some point, seems a bit pricey but I'm sure I'll find some soon enough (17-12-2014, 05:12 PM)RetroPug Wrote: You can buy flat sheets of carbon fibre online, they aren't cheap but for std. rectangular sheets they aren't ridiculous I suppose. Me and SlamWagon got some 2mm thick plastic sheeting so it will be light weight enough (17-12-2014, 05:21 PM)Norledge Wrote: Strip that door properly... May do some of the door but sod doing the boot
17-12-2014, 11:03 PM
(17-12-2014, 06:20 PM)Nathan1305 Wrote:(17-12-2014, 05:12 PM)RetroPug Wrote: You can buy flat sheets of carbon fibre online, they aren't cheap but for std. rectangular sheets they aren't ridiculous I suppose. CF won't really be much lighter, it will just look cool.
18-12-2014, 02:11 AM
Always bit comming up on ebay and Facebook french car selling page
Very interesting so far
18-12-2014, 12:37 PM
(17-12-2014, 11:03 PM)RetroPug Wrote:(17-12-2014, 06:20 PM)Nathan1305 Wrote:(17-12-2014, 05:12 PM)RetroPug Wrote: You can buy flat sheets of carbon fibre online, they aren't cheap but for std. rectangular sheets they aren't ridiculous I suppose. I'm carbon wrapping it ![]() (18-12-2014, 02:11 AM)7057sam Wrote: Always bit comming up on ebay and Facebook french car selling pageThanks mate glad there is some interest in it, going to be fun
18-12-2014, 04:40 PM
(This post was last modified: 18-12-2014, 04:50 PM by Nathan1305.)
[attachment=20689]
So started more stripping today got rid of these things for the door cards, every bit counts.[attachment=20690] Then started on the door looms [attachment=20691] Then cleared all the unnecessary stuff out of the centre console.. So nothing's left [attachment=20692] Then started the most daunting part in my view and that was thining the loom [attachment=20693] Did as much as could with what day light was left. Took all the.. Door looms out Radio wiring and antenna wires Rear speaker wire And some other bits [attachment=20694] This is the wires I took out today really pleased with myself considering i don't really know anything about wiring. I tried starting the car and it wouldn't fire so I had a panic but thought I'd check the fuses and luckily it was just one fuse. So replaced it and now it's all good happy days
18-12-2014, 07:45 PM
Tomorrow will consist of collecting some plastic sheeting from Ian to make some door cards and some dash inserts, then ripping the dash out so I can get some more wiring out and the heater box thing and heater matrix
19-12-2014, 12:19 AM
id have removed the full dash 1st and then chased what wires are what, as you may be able to remove more from the car loom.
19-12-2014, 12:37 AM
(This post was last modified: 19-12-2014, 12:38 AM by Nathan1305.)
(19-12-2014, 12:19 AM)procta Wrote: id have removed the full dash 1st and then chased what wires are what, as you may be able to remove more from the car loom. That's what I'm doing tomorrow just got the ones I could see today so I'll be getting the dash out tomorrow and take other stuff that's not needed out, not sure what other wires can come out to be honest
19-12-2014, 12:58 AM
(19-12-2014, 12:37 AM)Nathan1305 Wrote:anything to do with the air bag and other odds and ends that you are not going to use, but bare this in mind, are you going to run after market gauges or a custom dash?(19-12-2014, 12:19 AM)procta Wrote: id have removed the full dash 1st and then chased what wires are what, as you may be able to remove more from the car loom. as you will need some sort of power ISO connector is a good one for power, so remember that before you chop it all out, speaker wires you can bin also the speaker iso connector can go, but the other id keep for the power. ariel wire can bite the dust too.
19-12-2014, 05:24 PM
[attachment=20699]
Had a fun day ripping the dash out ready to get rid of some more wiring, only issue I have is it seems to be revving lumpy. Only thing I disconnected was the clocks and the stalks. Anyone know why it could be doing this?
19-12-2014, 06:13 PM
that looks ready for a full blown cage!
19-12-2014, 06:17 PM
19-12-2014, 06:44 PM
plug them back in and see if it sorts it out, could be the earths, as my indicators wont work if my hazard switch isn't connected up,
19-12-2014, 07:09 PM
(This post was last modified: 19-12-2014, 07:20 PM by Nathan1305.)
29-12-2014, 02:29 PM
[attachment=20814]
Dash is back in the car and hopefully sorted the lumpy revving out. I've replaced the plugs and left it to run for a bit and it all seems okay only issue is the engine management light comes up and goes out every now and then not sure what this could be but it seems okay
still more to come off that dash! Glove box, vents , clock surround and steering cowling too. f*ck it get the full lot removed and binned
29-12-2014, 02:53 PM
29-12-2014, 03:23 PM
(29-12-2014, 02:53 PM)Nathan1305 Wrote:(29-12-2014, 02:34 PM)procta Wrote: still more to come off that dash! Glove box, vents , clock surround and steering cowling too. f*ck it get the full lot removed and binned buy a second hand one and do it, just to see what it looks like, saves you f*cking up yours.
Nice to see it temporary fixed it
Take it the dash is staying in? Astor 6 Fast road/track project
29-12-2014, 10:35 PM
You can remove those 2 boot lining bits of carpet, I assume if they are like the ones in the 306 the glue is actually pretty shit.
There is loads of stuff in the engine bay that can be stripped, all the plastic covers and stuff can go and there is always loads of spare wiring in there. If you have stripped all the looms out the door you can do the same to the boot and either get pins for it or a cable pull for the inside to pull the locking lever for it. You can also get a smaller washer bottle and relocate it to the back of the car and remove the hose for the rear washer.
30-12-2014, 12:09 AM
(29-12-2014, 06:13 PM)7057sam Wrote: Nice to see it temporary fixed it Not sure what I can replace the dash with so I'm thinking of taking it back out and cutting parts of it out (29-12-2014, 10:35 PM)Dum-Dum Wrote: You can remove those 2 boot lining bits of carpet, I assume if they are like the ones in the 306 the glue is actually pretty shit. What's the boot lining bits of carpet? And yeah I'm going to strip the wires out the boot. Need to take it for a quick spin to make sure it's all running fine (30-12-2014, 12:09 AM)Nathan1305 Wrote: What's the boot lining bits of carpet? And yeah I'm going to strip the wires out the boot. Need to take it for a quick spin to make sure it's all running fine [attachment=20818] Is your boot light enough to be supported by just 1 ram? Infact do you even need them at all?
30-12-2014, 11:47 AM
(30-12-2014, 12:52 AM)Dum-Dum Wrote:(30-12-2014, 12:09 AM)Nathan1305 Wrote: What's the boot lining bits of carpet? And yeah I'm going to strip the wires out the boot. Need to take it for a quick spin to make sure it's all running fine Ah got you do you just scrape it off? And I'm thinking of taking the gas stut things off the boot it's not like it's going to be opened a lot
30-12-2014, 12:06 PM
Hmm I see a dash that has serious weight issues, break out the saw on the glove box bit if your after keeping the dash.
30-12-2014, 12:13 PM
(29-12-2014, 03:23 PM)procta Wrote:(29-12-2014, 02:53 PM)Nathan1305 Wrote:(29-12-2014, 02:34 PM)procta Wrote: still more to come off that dash! Glove box, vents , clock surround and steering cowling too. f*ck it get the full lot removed and binned You could also get it flocked or buy some faux suede and wrap it out of the car while you're at it and then just swap them over.
30-12-2014, 12:26 PM
Thank you for all the advice guys
dash is coming back out tomorrow and being cut up gas struts are coming out the boot along with the wires and the sound deadening in the boot is being taken out
