Threads: 591
54
Exhaust is just a old fogey of an MOTer. Get him to prove its louder than standard!!
Just service the front calipers, should sort it
Threads: 541
124
Just to add to the above take apart the front calipers grease the sliders (not copper grease) under the dust covers and pump them in and out a bit to make sure they slide well.
Re copper crease the pads so they can move freely then push the piston back in and pump it out (not too far) a few times to make sure its free.
Would take less than an hour a side.
Threads: 476
81
Car Model/Spec: 306 Rallye
Rebuild the front callipers should fix that stuff. The exhaust is just a PITA.
Threads: 145
5
as has been said, re brakes, sliders must be free, and the pistons should go back into the caliper body with heavy thumb pressure, taking the M/C top off would help but watch out for fluid spillage............a g clamp set up on the caliper and piston could act as a spring to return the piston when foot off the brake pedal to "exercise" the pistons........since seals etc are available then an overhaul isn't too painfull but be carefull with the pipes......also make sure the pads don't stick in their respective "channel".........if the front are badish, how are the rears?? whaty colour is the fluid.........
I presume the tiny recouperating port in the M/C is clear.......
as to noise, the manual says.......etc..........a wraaaaaaah exhaust tends to suggest ( I'm ducking now ) a boy racer........
