	Threads: 164
25 Location: Honiton
 Car Model/Spec: Gti6
 Thanks: 0Given 4 thank(s) in 4 post(s)
		28-09-2014, 09:01 PM
(This post was last modified: 28-09-2014, 09:03 PM by rocker8742.)
		What is this plug for? Behind the inlet/throttle body on the 6
2 pin black plug anyone know?
 ![[Image: hy2a8u2y.jpg]](http://img.tapatalk.com/d/14/09/29/hy2a8u2y.jpg)
Orrrr any sensors that would fail suddenly and leave a gti struggling to pull and hunting at idle
Already checked the lambda and its not that
	Threads: 11
0 Location: Stockholm, Sweden
 Car Model/Spec: 306 GTI-6 trackday toy
 Thanks: 0Given 2 thank(s) in 2 post(s)
		Icv? Under the throttle body.
	Threads: 164
		28-09-2014, 09:27 PM
(This post was last modified: 28-09-2014, 09:57 PM by rocker8742.)
		Checked the icv mate its not that afaik
	Threads: 386
87 Location: Suffolk
 Thanks: 1Given 118 thank(s) in 117 post(s)
		Think that plug's for the inlet air temp sensor?
 Hunting and struggling to pull sounds like a broken MAP sensor though.
	Threads: 183
20 Location: eastwood/notts
 Thanks: 0Given 8 thank(s) in 8 post(s)
		Its a free plug mate! Pretty sure mine has it!
#2 Moonstone Blue HDI ![[Image: 6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg]](http://i512.photobucket.com/albums/t326/kent16_2008/6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg)
	Threads: 18
10 Location: Wiltshire
 Car Model/Spec: 3 x 205 GTi & 306 HDi
 Thanks: 3Given 17 thank(s) in 17 post(s)
		As above, the black 2-pin plug is unused on UK cars.
 (for reference of the above posters, on a GTi-6 the IAT plug is grey and the ICV is a black 4 pin ovalish connector and not a JPT like shown)
	Threads: 476
81 Location: Ipswich
 Car Model/Spec: 306 Rallye
 Thanks: 4Given 104 thank(s) in 102 post(s)
		This question comes up time and time again.... i may be stupidly wrong but wasnt it something like a throttlebody heater for colder climates or something?
	Threads: 18
		Throttle heater plug is yellow and is used on UK cars despite not really being needed in our mild climate.
	Threads: 476
		oh thatll be what i was thinking of then!
	Threads: 164
		Damn was hoping its be the problem, is a map sensor likely to go faulty all of a sudden?
	Threads: 18
		They can do, as can ignition coils - both common on '6 engines.
	Threads: 386
		 (29-09-2014, 09:50 AM)powerandtorque Wrote:  As above, the black 2-pin plug is unused on UK cars.
Any idea what it's used for on the non-UK models?  Something to do with cruise control maybe?  Just intrigued now lol.
  (29-09-2014, 04:21 PM)rocker8742 Wrote:  Damn was hoping its be the problem, is a map sensor likely to go faulty all of a sudden?
Can do yeah.  One failed on SRowells 1.8 without warning...at the time we went to the scrappy to get a load of spare sensors to try...all except a MAP sensor.
Ph2 '6s aren't OBD compatible are they?  And I guess you don't have PP2k?
	Threads: 164
		No haven't got any diagnostics stuff .Got a spare map sensor which il try tonight , fingers crossed .
	Threads: 476
		so they have a plug but they cant be read by most readers. think its only peugeot plane that will do the job.
	Threads: 386
		Yeah didn't think they would be.  They didn't need to be OBD compatible until 2001.  So it is only Pug Planet you'd be able to check with unfortunately.
 Might as well try the MAP as you've already got it spare though!
	Threads: 164
		Swapped the map sensor over and it appears to have fixed the issue, odd that it went all of a sudden thoug
	Threads: 19
12 Location: Devonshire
 Thanks: 4Given 25 thank(s) in 24 post(s)
		 (29-09-2014, 07:05 PM)rocker8742 Wrote:  Swapped the map sensor over and it appears to have fixed the issue, odd that it went all of a sudden thoug
It's peugeot nothing is 'odd'
glad to hear its back to normal
	Threads: 128
21 Location: Cardiff
 Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
 Thanks: 1Given 41 thank(s) in 38 post(s)
the weather became considerably colder over the last few days mate, so possibly that had an effect on the vehicle,  and this wasnt a noticable issue prior to that.. but now is..
Given the choice between Niall and the sheep. I would choose the sheep!/Toseland
	Threads: 541
124 Location: Aylesbury
 Thanks: 7Given 59 thank(s) in 58 post(s)
		 (08-10-2014, 02:04 PM)toseland Wrote:   (29-09-2014, 07:05 PM)rocker8742 Wrote:  Swapped the map sensor over and it appears to have fixed the issue, odd that it went all of a sudden thoug the weather became considerably colder over the last few days mate, so possibly that had an effect on the vehicle,  and this wasnt a noticable issue prior to that.. but now is..
Yeah my car is being a right bitch since the temperature has dropped 10 degrees.
	Threads: 128
		which one? the decent one or that shitty Faillye
	Threads: 465
114 Location: Cullompton Devon
 Car Model/Spec: Vauxhall
     Thanks: 1Given 98 thank(s) in 92 post(s)
		Tom i have planet here if you needed to plug it in to have a view at whats being read by the sensors
	Threads: 26
4 Location: Monaghan/fermanagh.
 Thanks: 1Given 6 thank(s) in 6 post(s)
		Just for future ref, you dont need pug planet for ph2's, my delphi system reads them fine.
	Threads: 591
54 Location: Cotswolds
       Thanks: 22Given 68 thank(s) in 68 post(s)
		 (09-10-2014, 05:16 PM)toseland Wrote:  which one? the decent one or that shitty Faillye
Rep'd!!
	Threads: 164
		 (09-10-2014, 05:26 PM)cully Wrote:  Tom i have planet here if you needed to plug it in to have a view at whats being read by the sensors
Will bear that in mind for future mate
