Threads: 266
18
Car Model/Spec: 205 DTurbo
24-06-2014, 11:21 AM
(This post was last modified: 24-06-2014, 11:23 AM by silverzx.)
So I've got my cable, circuit breaker, terminal clamps and cut off switch for the Datsun.
How can I join the existing live to my cable safely?
I kind of want a clamp like on the terminal clamp but just for joining wires.
I've typed a few things into eBay/Google but can't find what I'm looking for..
Heavy duty crimps?
Any suggestions?
Threads: 142
58
Car Model/Spec: E46 BMW 320d
Electrical tape?
Threads: 448
51
Twist together
Job jobbed
Scotch lock and clingfilm....
Threads: 169
91
Get appropriately sized crimps. Crush them with a vice (unless you have hands like the hulk  ) and then slap some solder around the wire to the crimp. Belt and braces
Threads: 127
33
Car Model/Spec: ZX Volcane TD
yeah solder the ends into big ass connectors and use a distribution block
Threads: 266
18
Distribution block was the words I was looking for.
Threads: 127
33
or bolt them together if you're feeling cheap and cover in electrical tape
81
(24-06-2014, 12:47 PM)silverzx Wrote: Distribution block was the words I was looking for.
It took me a while to work out those words too! They seem to cost more than you would expect!
Threads: 266
18
(24-06-2014, 01:01 PM)SRowell Wrote: (24-06-2014, 12:47 PM)silverzx Wrote: Distribution block was the words I was looking for.
Proper job seem to do them dirt cheap.
And pocket size... If thats your thing...
Threads: 465
114
Car Model/Spec: Vauxhall
you need Copper Tube Butt Connectors for cable Size 25 mm² and a good crimper dont expect to do them with plyers
http://www.ebay.co.uk/itm/Copper-Tube-Bu...4cfbe8a5c7
Threads: 266
18
24-06-2014, 01:24 PM
(This post was last modified: 24-06-2014, 01:37 PM by silverzx.)
(24-06-2014, 01:14 PM)cully Wrote: you need Copper Tube Butt Connectors for cable Size 25 mm² and a good crimper dont expect to do them with plyers
Thanks Cully, best get some tape too, don't want those big chunks of metal being exposed!
Edit: Less and cheaper:
www.ebay.co.uk/itm/261060050738 x 6 £3.29
www.ebay.co.uk/itm/251101053397 x 10 £4.59
Or if you fancy a free torch...
www.ebay.co.uk/itm/320997880550 x 25 £8.73
Don't expect to do the ground with just connecting it to the chassis - seen it, tried it, never works, engine will crank insanely slow.
You *need* to run a +ve and -ve cable from my experience.
Threads: 266
18
(25-06-2014, 08:28 AM)Ruan Wrote: Don't expect to do the ground with just connecting it to the chassis - seen it, tried it, never works, engine will crank insanely slow.
That's how it's been for the last year and not had a problem bro-ski.
Threads: 128
21
and its almost guaranteed to be better if you have a dedicated negative connection from engine to battery
/Toseland
Threads: 266
18
(25-06-2014, 10:18 AM)toseland Wrote: and its almost guaranteed to be better if you have a dedicated negative connection from engine to battery
I'll have a looksie!
Threads: 128
21
well, quickest test, grab a jump lead. clip it onto the starter mount, and 'tother end onto battery.. if it improves, you are onto a winner..
i have a 600amp cable running from negative terminal to the top of the alternator bracket (one that bolts on by the fuel pump)..
that, and tightened the dedicated one on the back of the engine and it starts like a boss now
/Toseland
Threads: 132
25-06-2014, 04:40 PM
(This post was last modified: 25-06-2014, 04:42 PM by Sambarker.)
Or maybe get one of these?
[attachment=17148]
And some decent crimp on ring terminals?
But surely if battery has a good ground to chassis, and engine has a good ground to chassis then there should be no problem? Never had an issue tbh.
(25-06-2014, 04:40 PM)Sambarker Wrote: But surely if battery has a good ground to chassis, and engine has a good ground to chassis then there should be no problem? Never had an issue tbh.
Correct you are sir. People get slower cranking cars when they relocate the battery because of two reasons. Either their short earth strap is not on a clean enough surface (does need to be bare metal!) or the ring connector they have used isn't big enough or they haven't factored voltage drop when sizing their + cable.
Threads: 266
18
(25-06-2014, 04:40 PM)Sambarker Wrote: Or maybe get one of these?
I already have one of those, plus a circuit breaker, plus cable.
Threads: 132
(26-06-2014, 08:36 AM)silverzx Wrote: (25-06-2014, 04:40 PM)Sambarker Wrote: Or maybe get one of these?
Well all that lot isn't going to help issues as it will all be adding resisitance
Threads: 266
18
I don't see why some people are so negative about it? It'll be fineeee!
It's just a simple relocate battery from behind passenger seat, where it currently has a cut of switch wired to the positive(+) and the negative(-) straight to the floor pan to the boot where it will have an added circuit breaker and another 1.5m of cable.
Happy dayssss!
I hear Dum-dum's a huge fan of those copper butt connectors, snigger snigger....
Threads: 208
60
(24-06-2014, 12:14 PM)Matt Wrote: Twist together
Job jobbed
Im going with this method
Threads: 266
18
So I have my 25mm cable, I have the big crimpy things, how do I join them together?
Crush them with a vice?
Do I need a beefy soldering iron? Any suggestions, links to eBay products etc all considered helpful.
Here's the connectors I bought:
Threads: 465
114
you need a heavy duty crimper for 25mm lugs
or you could solder the cables in
[attachment=18030]
this is cheap compared to what i paid for mine
http://www.ebay.co.uk/itm/Heavy-Duty-Cri...2a40ec325a
Threads: 266
18
(30-07-2014, 10:53 AM)cully Wrote: you need a heavy duty crimper for 25mm lugs
That looks bad - ass.
Threads: 226
24
Car Model/Spec: A3 TDi
Hammer and a really blunt chisel
Threads: 11
Car Model/Spec: 306 GTI-6 trackday toy
A proper crimp tool like the one above is what's needed for a decent connection, avoid solder as much as possible, it can cause the cable to break due to vibration hardening. There are cheap tools available where you but the tube connector in a v shaped indentation and then force a wide punch into the tube, either via a vise or a Mallet.
/Former boat electricity guy :-)
Tinkerer of 306gti6 trackday racer, less stuff, more hard, more umpf, more stop.
Interesting argument over crimp/soldering.
Some wont ever do any soldering in a car due to vibrations/heat etc...
Then others wont do anything BUT soldering!
With my experience of french electrics and crimped things coming apart....I always solder or where I can, both.
