	Threads: 9
		Help I have a 1.8 engine and loom and im puttin a gti in ive just recived the loom but the two plugs near the ecu box one is the right size but rhe other is different what do I do next
thanks mat
		Them two plugs plug in down by the N/S rad. You use both however the fact that one is brown suggests it could be a ph1 or 2 loom. Is the car ph1 or 2?
	Threads: 9
		22-07-2014, 06:09 PM
(This post was last modified: 22-07-2014, 06:21 PM by ayton autosport.)
		Its off a ph1 xsara and my cars a ph1 xsara they plug in by the blukhead on the n/s behind just behind the ecu
Heres where the loom connects to then goes to the clock and dash, both the new loom and my car are both ph1 xsaras
		Ah sorry didn't realise it was a Xsara. Cant help then I'm afraid!
	Threads: 9
		Sam whats your loom like were it's connected here
mat
	Threads: 9
		Has anyone put a gti6 head on the 1.8 block I need to know what im going to do with the wiring seems ill have to cut and join the plug but im not sure which wire to which
mat
