loom problem - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: loom problem (/showthread.php?tid=25433) |
loom problem - ayton autosport - 22-07-2014 Help I have a 1.8 engine and loom and im puttin a gti in ive just recived the loom but the two plugs near the ecu box one is the right size but rhe other is different what do I do next thanks mat RE: loom problem - Niall - 22-07-2014 Them two plugs plug in down by the N/S rad. You use both however the fact that one is brown suggests it could be a ph1 or 2 loom. Is the car ph1 or 2? RE: loom problem - Eeyore - 22-07-2014 wow thats very dirty D: RE: loom problem - ayton autosport - 22-07-2014 Its off a ph1 xsara and my cars a ph1 xsara they plug in by the blukhead on the n/s behind just behind the ecu Heres where the loom connects to then goes to the clock and dash, both the new loom and my car are both ph1 xsaras RE: loom problem - Niall - 22-07-2014 Ah sorry didn't realise it was a Xsara. Cant help then I'm afraid! RE: loom problem - ayton autosport - 23-07-2014 Sam whats your loom like were it's connected here mat RE: loom problem - ayton autosport - 23-07-2014 Has anyone put a gti6 head on the 1.8 block I need to know what im going to do with the wiring seems ill have to cut and join the plug but im not sure which wire to which mat |
