	Threads: 15
Car Model/Spec: D turbo s
		24-04-2014, 02:02 PM
(This post was last modified: 24-04-2014, 02:02 PM by jack123sand.)
		What's the blue arm for and where do I buy one its missing on mine this is a pic of another???? Plz help[/php]
On a lucus pump
	Threads: 131
6
Car Model/Spec: MX5
		got any more pictures? really cant see what im looking at
![[Image: attachment.php?aid=5522]](http://306oc.co.uk/forum/attachment.php?aid=5522)
Car Model/Spec: 306 D Turbo
		Looks like the wax stat on a Lucas pump? If so just get down the breakers and get a new one.
	Threads: 15
		Been to peugeot garage they say its not a wax stat and they cart find the part been to various diesel men they don't know??
	Threads: 2
Car Model/Spec: 1998 / XUD9 Turbo
		had the same arm on my Lucas pump, but one side was to wide, so didn't stayed on...
few weeks later lost mine as well...
only thing I can tell you, if you rotate the arm on the side of the pump to a horizontal level,
the motor doesn't run smooth anymore when you just started it...
when temperature is normal, can't find any difference...
	Threads: 131
6
Car Model/Spec: MX5
		Is it at the back if the pump?
	Threads: 31
Car Model/Spec: tu5 bitza/cherry dt
	Given 5 thank(s) in 5 post(s)
		Must be the back I see glow plugs, the only thing I can think of is that it's the cold idle lever
	Threads: 142
11
Car Model/Spec: ph1 DT estate , 207 1.6 hdi
		if you want to refit it I have  a lucas pump sat in the shed you can have the part for nowt if you collect.
	Threads: 15
		I've found one now but still know idea what it is thanks anyway guys
