	Threads: 40
2
Car Model/Spec: DTURBO
	Given 5 thank(s) in 5 post(s)
		What is the best way to get the inner smaller bearings into a beam without making sh1t of them?
Is the 35mm socket and hammer way a bit risky?[/b]
                                                      HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
	Threads: 79
17
Car Model/Spec: Down and out HDi racestate
		23-04-2014, 01:41 PM
(This post was last modified: 23-04-2014, 01:42 PM by Slam Wagon.)
		Aslong as your pressing against the outside of the bearing you should be fine. Any pressure on the inside of the bearing is when damage gets caused. Bit of lube to help it slide in will help.
Ive never done it so im not speaking from experience.
	Threads: 40
2
		 (23-04-2014, 01:50 PM)welshpug Wrote:  you need something that is a slide fit in the beam tube, as large as possible a diameter, a 35mm socket isn't ideal as it has a chamfer which will fold over the edge of the bearing.
the ideal tool is the Citroen original toolkit
no need for lube around them, but you do need to pack the bearing thoroughly before installing them.
Cheers
Hubnut socket not be alryt as theres no chamfer?
	Threads: 42
28
		not seen one ever without a chamfer or big enough.
	Threads: 18
10
Car Model/Spec: 3 x 205 GTi & 306 HDi
		If you've nothing proper to do the job, an old trailing arm shaft (thicker end) works well
	Threads: 371
29
Car Model/Spec: ford fiesta
		Old trailing arm.shaft FTW
	Threads: 122
9
Car Model/Spec: Kingfisher Ph1 Dturbo S
	Given 7 thank(s) in 7 post(s)
		Dont mean to brag but weve got the genuine peugeot axle kit at work and it makes life so easy.
We used to be a peugeot specialist and have all the special tools
	Threads: 122
9
		23-04-2014, 07:58 PM
(This post was last modified: 23-04-2014, 07:58 PM by Jimbo.)
		Our instructions got lost too probably back along when the old beys used to repair 205/309 axles.
We've worked out what does what though
	Threads: 371
29
		Either one of you guys near ipswich then so I can borrow the drift
	Threads: 40
2
		Thanks. Mite give the shafts a go, there a couple mil too thin tho.
	Threads: 70
10
Car Model/Spec: HDi Estate
	Given 9 thank(s) in 9 post(s)
		Photos of the genuine Peugeot/Citron kit?
	Threads: 371
29
		I've already got two I'm rebuilding myself I don't need a third I used to have access to the tools working for peugeot but I left
	Threads: 145
5
		is there any way of greasing these bearings?? like a grease nipple or summut??
	Threads: 371
29
		I've heard of people tapping a grease nipple into the beam on the 205gtidrivers forum with varying success. I would just make sure they are well lubricated before they go in and you should be fine.
	Threads: 42
28
		just grease them well when fitting, then fit new bearings a few years down the line.
grease nipples dont work.
