Help please.... Before i burn it.
White smoke often indicates timing too retarded. It's only partially combusting causing the white smoke.
#32
thought so, is there any trick to getting these things timed properly, they seem to just be a pig
#33
Its alive and running well Big Grin
now it seems clutch is slippping... peugeot life...
#34
Good stuff sweeney, glad you got it sorted!
Put a td04 on it, itl move the torque up the rev range and save your clutch Wink
#35
nah cant be arsed with that, its a daily hack so i'll just go easy until i can afford new one, its not too bad just when you hit it hard, on 130k so probably on orginal clutch
I put on a k03 turbo while i had turbo off, like the quick spool Wink
#36
My car is on 190k on the original clutch. It started to slip when I had the gt15, td04 solved that and still got 170bhp Big Grin
#37
interesting alright, must be the lower end torque, something to look into at some stage..
