I hace some cuestions of my car
Hi i am a new owner of 306 diesel model of 96.
What phase it is?
Is normal to have vibration when you power it on...?
How can i bost my engine for free??
Welcome to the club, you probably have a phase 1, have a look in the guides section for tuning advice Smile
Hi,
I had vibrations while accelerating, it was a bolt missing from the fuel pump bracket, easy fix.
For boost, type "stage 1 tune" into YouTube Darrenjlobb has a great video many people have used.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
96 is most probably a phase one as said above.
Vibrations when accelerating could be engine mounts, a loose bolt, maybe something rubbing on the chassis. Could be a whole host of things, you will need to look into that one on your own.
And tuning get on youtube theres a few videos on there, or search around on here and google.
Threw afew phase 2 p reg too.
(16-03-2014, 09:36 PM)Tom Wrote: 96 is most probably a phase one as said above.
Problem only is present when i power on the car witout accelerating it...
This car have ecu port for be sure is not a electrical problem or other thing
96 is more than likely XUD not hdi. Which means it has no ecu and is mechanically controlled. I would say its an engine mount, i would start by checking the lower mount.
