Hi i am a new owner of 306 diesel model of 96.
What phase it is?
Is normal to have vibration when you power it on...?
How can i bost my engine for free??
Welcome to the club, you probably have a phase 1, have a look in the guides section for tuning advice
Hi,
I had vibrations while accelerating, it was a bolt missing from the fuel pump bracket, easy fix.
For boost, type "stage 1 tune" into YouTube Darrenjlobb has a great video many people have used.
96 is most probably a phase one as said above.
Vibrations when accelerating could be engine mounts, a loose bolt, maybe something rubbing on the chassis. Could be a whole host of things, you will need to look into that one on your own.
And tuning get on youtube theres a few videos on there, or search around on here and google.
Threw afew phase 2 p reg too.
(16-03-2014, 09:36 PM)Tom Wrote: [ -> ]96 is most probably a phase one as said above.
Problem only is present when i power on the car witout accelerating it...
This car have ecu port for be sure is not a electrical problem or other thing
96 is more than likely XUD not hdi. Which means it has no ecu and is mechanically controlled. I would say its an engine mount, i would start by checking the lower mount.
