Wanted: S16 Diaphragm
As titled I'm after a S16 diaphragm for the inlet manifold. 1 for the cam belt end. Not sure if there different for each end. Maybe be interested in a pair though. Must be in working order and have the nipple to connect the pipes
They are both the same, mountedon a metal plate that screws to the bottom, you can swap these over
If your careful it is possible to pride them open and re glue the membrane inside if that has split
Bump on this.
Started driving the s16 again and 1 of the diaphragms isn't work and not holding vac so is anyone able to help me out?
mr superglue to repair the diaphram
Might take it off and have a look/go at sorting fixing it
Bump on this if anyone does have some spares as i have run out of spares
Gti6 inlet problem solved
(13-03-2014, 07:46 PM)Josh_Quant Wrote: Gti6 inlet problem solved
What's it like to fit 1 onto a S16?
easy..
Not giving touch away then? Lol
Is your 205 on the road?
Anyone help me? I rung peugeot and they cant get them any more Sad
Frosty, did you have much luck? the rubber on my diaphragm (cambelt side) has broken so i'm after either a new or one with a broken nipple Wink
I managed to get a new 1 from Peugeot but was the last 1 they had
