Threads: 49
Car Model/Spec: HDI phase 3
Hi guys quick question I have a knocking noise from my engine bay on drivers side. The speed of knocking increases on acceleration. What could it be?
On a side note I have just done CAMBELT KIT and aux belt tensioner and idler could it be that is knocking
Got to love it when you have no idea
Threads: 87
48
(18-02-2014, 11:45 PM)camoturd Wrote: Hi guys quick question I have a knocking noise from my engine bay on drivers side. The speed of knocking increases on acceleration. What could it be?
sounds like it mate, i wouldn't be driving it until you find out tbqh . .
Does it increase relative to engine speed or to road speed?
Threads: 58
Car Model/Spec: v70r
Get light between the engine and inner bay and see if anything is hitting
Threads: 49
19-02-2014, 08:13 PM
(This post was last modified: 19-02-2014, 08:15 PM by camoturd.)
Yeah its is strange if it was anywhere else I would of thought it was a tappet
Bit have noticed it starts at about 2500 rpm and dies at 4000 rpm and happens under heavy acceleration
Take aux belt off.
If noise dissapears then its on the aux setup
Threads: 122
9
Could be.injectors worn on hdi
Have a light tapping noise under load up until around 3200rpm usually?
I did changed injectors and.noise gone
What youre describing sounds nothing like injectors.
It doesn't sound good though, is your crank pulley all good?
Threads: 49
No idea how to tell if it's not
Threads: 28
Car Model/Spec: Stage 1 HDi
Sorry for the thread hijack but ive a knock from my front drivers well when turning, theres a couple of wee knocks when youve the wheel turned fully right and turning tight ie swinging the car round in a carpark my initial thought was droplinks?
Threads: 9
Could be CV joint if it only happens when turning.
Previous Car: Peugeot 306 XLdt (stock!), 150,000 miles (I miss this car
Get the drivers side in the air and take the front wheel off. Have a look at the pulley with the engine running, if its knackered it'll wobble or run off-centre, there'll probably be rust marks and perishing too.
