	Threads: 4
Car Model/Spec: 306 HDi
		I put £20 in and got ~160 miles which i believe equates to 49mpg if i can do maths, i consider myself a careful driver who doesn't drive particularly fast, about 120 miles were driven on the motorway in stupid 50mph average speed checks with the rest in an urban environment.
I'm worried this is a bit low? as this car can do 65mpg, especially the way i drive i'd expect 50+ easily.
The car has recently been serviced, am i just being paranoid or is something likely wrong with the car?
	Threads: 19
5
Car Model/Spec: Ph1 D-turbo(on going project)
		Its a 12 year old car, its not going to have the same figures from factory, and doubt that they ever did 65mpg
May be in perfect test condition.....
I usually get 30mpg in mine, but i do drive like a loon...
	Threads: 591
54
		Thats pretty good going imo
What wheels/tyres you got? Pressures correct? Did you use the AC at all?
Ive never known hdi manage 60 or more
	Threads: 386
87
		50mpg is about right for a HDi tbh....  You wont manage over 60 unless you sit on the motorway, slipstreaming at 56mph for hours lol...
	Threads: 34
1
Car Model/Spec: 306 1.9
		49 sounds good to me too, i get about 40 in my xud mixed driving
	Threads: 117
119
		49mpg with that kind of mix is fine, especially with the weather we've got at the moment.
	Threads: 18
10
Car Model/Spec: 3 x 205 GTi & 306 HDi
		As above, most HDi's seem to be around 50mpg average driven half-sensibly and the current cold weather (and thus prolonged warm up) does impact economy a little.
However, I'm not convinced that measuring fuel economy based on putting a set amount of fuel in is the best way to go about it as that opens up too many variables IMO.  Best way is to brim the tank, drive until it's nearly empty and brim again, ideally averaging over several tanks.
For what it's worth, the average of my HDi hatch is 50.5mpg over the last 48k miles.  Steady motorway driving going to Munich and back a couple of years back gave ~55mpg, so I would treat that as the highest that you'll likely realistically get without actively trying to drive in an economical manner.
	Threads: 541
124
		As above thats not unreasonable.
Think my HDi is averaging the low 40s at the moment with about 50/50 motorway and town.
Check your tyre pressures, make sure your egr isn't leaking, you don't have a boost leak, your cat isn't getting blocked and your MAF is perfect and you might get a couple more MPG
It is possible to get 60mpg+ MPG but it really is 60mph on the motorway in a well maintained car on a summers evening
	Threads: 4
		Thank you for your replies. Can stop worrying that somethings wrong with the car! Well something wrong with the engine, theres lots wrong with the car.
Got cyclones, cant remember the tyre profile. The pressures will be good, i have to keep checking them cus theres a slow leak on one of them.
Was worrying might be something to do with the exhaust, when i start the car theres a horrible knocking noise coming from the exhaust. Like its knocking against something when the engine bounces into life, the rear rubber mounts on the backbox recently gave way, had to replace them, doubt new stiff rubber mounts would make the noise. Do 306s have a middle mount on the exhaust? guess that might have come out.
	Threads: 117
119
		Do you get the same noise if you step on and off the accelerator suddenly? If so its your engine mounts, probably top or bottom.
