Threads: 13
2
Car Model/Spec: Whats a 306?
14-01-2014, 11:08 PM
(This post was last modified: 16-01-2014, 06:32 PM by Wor Jimmy.)
I'm making some Inlet adapters but I need some sizes! (MEASURE TWICE CUT ONCE  )
Can any one pitch some sizes? Thanks to ConorTRG for the sizes
Next on the list!
The size of the pipe. I can do it at 2.5" but case will hit the sound proofing so a small section will need to be cut out (40mm x 70mm)
Is this ok? or would people rather not cut a little section out? it might not even need it. as the boot shuts. its just a tight squeeze
(Ignore the welds on the top part.. its just a test part)
[attachment=12785]
...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
Threads: 541
124
I have no clue but keep up the good work and hopefully someone who knows will be along soon.
Threads: 13
2
(14-01-2014, 11:39 PM)Dum-Dum Wrote: I have no clue but keep up the good work and hopefully someone who knows will be along soon.
I Really should of posted it early in the night.. when people were up lol
Threads: 26
4
Given 6 thank(s) in 6 post(s)
I'll measure a manifold tomorrow if someone else doesnt sort you out first.
Threads: 171
46
Given 1 thank(s) in 1 post(s)
Not sure what engine section it falls under so you put it in the couch lol
Xud adapter so maybe the xud section?
Threads: 13
2
15-01-2014, 12:17 AM
(This post was last modified: 15-01-2014, 12:18 AM by Wor Jimmy.)
(15-01-2014, 12:10 AM)4WayDiablo Wrote: Not sure what engine section it falls under so you put it in the couch lol
I've been asked to make them for a 306 that is all, no other info was given lol heck not even all the flippin sizes.. As you can see this is a slick operation
(14-01-2014, 11:57 PM)ConorTRG Wrote: I'll measure a manifold tomorrow if someone else doesnt sort you out first.
Cheers mate, big help.
Threads: 171
46
Sounds like oc alright! Hahah
Threads: 541
124
(15-01-2014, 12:10 AM)4WayDiablo Wrote: Xud adapter so maybe the xud section?
306 owners club forum so maybe 306 owner?
No?
f*ck off to the hairdressing land then
(joking, love you really)
Threads: 13
2
(15-01-2014, 12:20 AM)Dum-Dum Wrote: (15-01-2014, 12:10 AM)4WayDiablo Wrote: Xud adapter so maybe the xud section?
No?
Hairdressing? ? Ahh Fu*k the secret is out!
Threads: 171
46
Its only a hobby!
Honest!....
Threads: 77
15
Car Model/Spec: oem+ phase 3 astor 6
Threads: 142
58
Car Model/Spec: E46 BMW 320d
Moved to the xud section for the time being, can always move it again if necessary.
Threads: 26
4
These are my measurements:
A - 35mm
B - 24.5mm
C - 86.5mm
D - 26.5mm
E - 10mm
F - 28mm
G - 121mm (Measurement wrote in blue on your picture)
Threads: 13
2
Cheers bud will note them down when I get in
Threads: 13
2
Reet! That is the base plate done  Cheers again.
Threads: 26
4
Threads: 13
2
(15-01-2014, 09:20 PM)TallGuySmallBike Wrote: Reet! That is the base plate done Cheers again.
Getting there..
(ignore the welds on the top part.. its a test part)
[attachment=12784]
Threads: 122
9
Car Model/Spec: Kingfisher Ph1 Dturbo S
Given 7 thank(s) in 7 post(s)
Looks too high?? Wen me and a mate were making/selling these they were alot shorter :/
Threads: 13
2
16-01-2014, 11:12 PM
(This post was last modified: 16-01-2014, 11:13 PM by Wor Jimmy.)
(16-01-2014, 10:27 PM)Jimbo Wrote: Looks too high?? Wen me and a mate were making/selling these they were alot shorter :/
Its to fit 2.5" pipe, its 2.75" high (70mm)  (its also waaay to wide lol, it was just a test part tbh)
Been asked for 2" . 2.25" and 2.5" lol
What was the most common size you did?? Or did you just do a one size fits all?
Threads: 343
15
Car Model/Spec: 106 gti / 306 hdi estate
Given 3 thank(s) in 3 post(s)
Defo looks very tall think that will hit the bonnet like it is.
Threads: 13
2
(16-01-2014, 11:19 PM)Chris_90 Wrote: Defo looks very tall think that will hit the bonnet like it is.
hits the sound proofing. clears the bonnet. Like I said.. test part
Threads: 127
33
Car Model/Spec: ZX Volcane TD
16-01-2014, 11:31 PM
(This post was last modified: 16-01-2014, 11:31 PM by zx_volcane.)
2.5 is overkill surely
2.25 should be big enough for anyone
I'm still running 2 inch pipe for the majority of my intercooler pipe work
Threads: 13
2
(16-01-2014, 11:31 PM)zx_volcane Wrote: 2.5 is overkill surely
Well nothing a band saw cant fix
I can do 2.25 o/d, will a 2" silicone joint fit over it?
Threads: 122
9
Threads: 13
2
(17-01-2014, 07:19 AM)Jimbo Wrote: All of ours were 2.25
Ok cheers dude, will cut the bits up after work
Threads: 13
2
(16-01-2014, 11:40 PM)TallGuySmallBike Wrote: (16-01-2014, 11:31 PM)zx_volcane Wrote: 2.5 is overkill surely
Like i said..
[attachment=12828]
Threads: 13
2
Busy day tomorrow...
Time to weld!
[attachment=12841]
Threads: 226
24
Car Model/Spec: A3 TDi
Looking forward to seeing these.
Threads: 122
9
Same should be nice bit of kit
Threads: 13
2
18-01-2014, 08:07 PM
(This post was last modified: 18-01-2014, 08:12 PM by Wor Jimmy.)
Spent a good 4-5 hours in the garage drilling the last of the holes, tac welding them into place for when I get some thicker mild steel welding wire. I've got some 0.8mm but I need thicker  (I did a test with the 0.8.. Looked shit)
[attachment=12892]
what they will look like, Nothing special.
[attachment=12893]
The pipe is welded on the inside so silicone pipe can go right up so it can look nicer.
(not sure what happened to the colour)
