I'm making some Inlet adapters but I need some sizes! (MEASURE TWICE CUT ONCE
Can any one pitch some sizes? Thanks to
ConorTRG for the sizes
Next on the list!
The size of the pipe. I can do it at 2.5" but case will hit the sound proofing so a small section will need to be cut out (40mm x 70mm)
Is this ok? or would people rather not cut a little section out? it might not even need it. as the boot shuts. its just a tight squeeze
(Ignore the welds on the top part.. its just a test part)
[attachment=12785]
I have no clue but keep up the good work and hopefully someone who knows will be along soon.
(14-01-2014, 11:39 PM)Dum-Dum Wrote: [ -> ]I have no clue but keep up the good work and hopefully someone who knows will be along soon.
I Really should of posted it early in the night.. when people were up lol
I'll measure a manifold tomorrow if someone else doesnt sort you out first.
Not sure what engine section it falls under so you put it in the couch lol
Xud adapter so maybe the xud section?
(15-01-2014, 12:10 AM)4WayDiablo Wrote: [ -> ]Not sure what engine section it falls under so you put it in the couch lol
I've been asked to make them for a 306 that is all, no other info was given lol heck not even all the flippin sizes.. As you can see this is a slick operation
(14-01-2014, 11:57 PM)ConorTRG Wrote: [ -> ]I'll measure a manifold tomorrow if someone else doesnt sort you out first.
Cheers mate, big help.
Sounds like oc alright! Hahah
(15-01-2014, 12:10 AM)4WayDiablo Wrote: [ -> ]Xud adapter so maybe the xud section?
306 owners club forum so maybe 306 owner?
No?
f*ck off to the hairdressing land then
(joking, love you really)
(15-01-2014, 12:20 AM)Dum-Dum Wrote: [ -> ] (15-01-2014, 12:10 AM)4WayDiablo Wrote: [ -> ]Xud adapter so maybe the xud section?
No?
Hairdressing? ? Ahh Fu*k the secret is out!
Its only a hobby!
Honest!....
Moved to the xud section for the time being, can always move it again if necessary.
These are my measurements:
A - 35mm
B - 24.5mm
C - 86.5mm
D - 26.5mm
E - 10mm
F - 28mm
G - 121mm (Measurement wrote in blue on your picture)
Cheers bud will note them down when I get in
Reet! That is the base plate done
Cheers again.
(15-01-2014, 09:20 PM)TallGuySmallBike Wrote: [ -> ]Reet! That is the base plate done Cheers again.
Getting there..
(ignore the welds on the top part.. its a test part)
[attachment=12784]
Looks too high?? Wen me and a mate were making/selling these they were alot shorter :/
(16-01-2014, 10:27 PM)Jimbo Wrote: [ -> ]Looks too high?? Wen me and a mate were making/selling these they were alot shorter :/
Its to fit 2.5" pipe, its 2.75" high (70mm)
(its also waaay to wide lol, it was just a test part tbh)
Been asked for 2" . 2.25" and 2.5" lol
What was the most common size you did?? Or did you just do a one size fits all?
Defo looks very tall think that will hit the bonnet like it is.
(16-01-2014, 11:19 PM)Chris_90 Wrote: [ -> ]Defo looks very tall think that will hit the bonnet like it is.
hits the sound proofing. clears the bonnet. Like I said.. test part
2.5 is overkill surely
2.25 should be big enough for anyone
I'm still running 2 inch pipe for the majority of my intercooler pipe work
(16-01-2014, 11:31 PM)zx_volcane Wrote: [ -> ]2.5 is overkill surely
Well nothing a band saw cant fix
I can do 2.25 o/d, will a 2" silicone joint fit over it?
(17-01-2014, 07:19 AM)Jimbo Wrote: [ -> ]All of ours were 2.25
Ok cheers dude, will cut the bits up after work
(16-01-2014, 11:40 PM)TallGuySmallBike Wrote: [ -> ] (16-01-2014, 11:31 PM)zx_volcane Wrote: [ -> ]2.5 is overkill surely
Like i said..
[attachment=12828]
Busy day tomorrow...
Time to weld!
[attachment=12841]
Looking forward to seeing these.
Same should be nice bit of kit
Spent a good 4-5 hours in the garage drilling the last of the holes, tac welding them into place for when I get some thicker mild steel welding wire. I've got some 0.8mm but I need thicker
(I did a test with the 0.8.. Looked shit)
[attachment=12892]
what they will look like, Nothing special.
[attachment=12893]
The pipe is welded on the inside so silicone pipe can go right up so it can look nicer.
(not sure what happened to the colour)
