15-01-2014, 11:18 PM
(This post was last modified: 25-09-2018, 05:59 PM by Wolverine1091.)
Delete
Delete
Delete
15-01-2014, 11:38 PM
Delete
15-01-2014, 11:41 PM
If you go round a corner smoothly and then turn the steering wheel suddenly a bit harder you can get the back to come out a bit more. its to do with the trailing arms passively steering. And then probably a ruined beam on top of that!
15-01-2014, 11:46 PM
Delete
15-01-2014, 11:48 PM
not any more i sorted mine
![]() the top engine mount cradle was broken i welded it up and chocked the top mount from moving too used to step off the gas and the back end would go light and try to overtake the front scary!
15-01-2014, 11:50 PM
Delete
15-01-2014, 11:54 PM
[attachment=12769]
[attachment=12770]
16-01-2014, 07:28 AM
Usual culprits are sticking rear brakes and worn out rear tyres. These are the only things which have caused oversteer for me, other than my accelerator interaction.
HDi Owner for 200k/9 years
16-01-2014, 08:13 AM
Are the beam mounts good? They can cause unpredictable turn in if they've collapsed.
Torsion bar snap back is also a problem with these cars
16-01-2014, 08:21 AM
16-01-2014, 08:29 AM
16-01-2014, 08:38 AM
Just get on with it. It makes for a more interesting drive lol
16-01-2014, 08:43 AM
I had solid rear mounts on my previous car. Loved every minute of them. You've gotta 'adjust' your driving style slightly, but definitely an improvement. But thats just me. Not everybody's cuppa tea
![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
16-01-2014, 12:02 PM
If your not lifting off the throttle mid corner and its sliding out then something is very wrong as the cars are biased towards understeer.
16-01-2014, 12:08 PM
Got Chinese Linglong budget tyres on the back? Such things are utterly dreadful in cold, wet conditions like we have now and yet still people fit them because they're a few quid cheaper than something reputable.
Assuming you've sensible rubber all round then I'd be checking the condition of the beam, the mounts and suspension componants very carefully - 306's will lift off oversteer to a mild degree, but certainly shouldn't be sliding around in normal daily driving in an unpredictable and unprovoked manner.
16-01-2014, 12:47 PM
If its cheap rubber boots on the back...that would do it
My old ph1 would act like a rwd hooligan on wet roundabouts with cheap yingyangs on Wishes for more power...
16-01-2014, 01:17 PM
(16-01-2014, 12:47 PM)Piggy Wrote: If its cheap rubber boots on the back...that would do it Now imagine how I felt in the rain, with solid rear mounts and Spec II's ![]() Life threatening combination! ![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
16-01-2014, 01:52 PM
So youre telling me... that my car spearing off in a random direction whilst going in a straight line... being unpredictable in corners... isnt normal? D:
I think there may be something wrong with my car.... Seriously on a left bend it can massively spear off left more than i predicted. But it doesnt do it going right D:
16-01-2014, 01:54 PM
Passive rear steering
Perv 306 1.6 5 Door Hore - Sold 110bhp 207 Hdi Sport - Used as a Brake 173bhp T25 Ph1 Diablo Dturbo - Scrapped Thirsty Bitch Volvo 850 Estate - Sold 51bhp Berlingo Nad DT Van - Sold Slow as f*ck Dispatch Work Horse www.prestige-auto-care.co.uk
16-01-2014, 01:58 PM
(16-01-2014, 01:52 PM)SRowell Wrote: Seriously on a left bend it can massively spear off left more than i predicted. But it doesnt do it going right D: Ovalled front hub or loose pinch bolt will do just that - best way I can describe it is an unpredictable lurch mid-corner after you've turned in just unsettles the car, just like you've suddenly added quarter of a turn of steering lock. Probably the drivers side hub if it does it on left hand bends.
16-01-2014, 01:59 PM
(This post was last modified: 16-01-2014, 02:00 PM by Jonny81191.)
meridian spec front suspension? that'll have an effect.
EDIT: bloody mini northern pikey forgetting to log out!! This was samss, not little Jonny Welding and fabrication projects undertaken, contact me for more information.
16-01-2014, 02:11 PM
Im genuinely surprised you chose to state that Sam, rather than troll the hell outta him
16-01-2014, 02:29 PM
I have a hdi dturbo and if I give that some stick on a long tight bend I can feel the back end stepping out
16-01-2014, 03:42 PM
(16-01-2014, 02:11 PM)Grant Wrote: Im genuinely surprised you chose to state that Sam, rather than troll the hell outta him well, I was tempted to do another "I'm coming out of the closet" thread again, but i was stumped for originality lol Member of the 99% warning or you're nothing club
16-01-2014, 04:57 PM
(This post was last modified: 25-09-2018, 06:00 PM by Wolverine1091.)
Delete
16-01-2014, 06:05 PM
(16-01-2014, 01:58 PM)powerandtorque Wrote:(16-01-2014, 01:52 PM)SRowell Wrote: Seriously on a left bend it can massively spear off left more than i predicted. But it doesnt do it going right D: sounds exactly like the problem i have :/ Im sure Niall and Grant will find something obvious!
16-01-2014, 06:12 PM
I just get lift off oversteer and a lot of it but then again my hdi is really low
16-01-2014, 06:13 PM
I've heard lowering does exaggerate it
Continental whats? If they're eco tyres then they certainly won't help, but if you've got something similar on the front then start looking elsewhere for the root of the issue. I'd suspect something knackered on the rear beam is the culprit.
Sam, get someone capable to look at your car sharpish, if you've noticed actually an issue by yourself then it's probably about to explode in a ball of flames. |
