	Threads: 448
51
		So looking at getting the rallye started again soon. So the engine has been stood for a while.
So I'm going to do a service, oil change, filter change, coolant change.
Turn the engine by hand for a couple of cycles.
Start?
Anything I should or shouldn't be doing?
	Threads: 61
	Given 6 thank(s) in 5 post(s)
		If it was me id start it get it up to temp then drop the oil and coolant
	Threads: 178
28
Car Model/Spec: HDi!
		I wouldn't start it.
I'd drain and flush the oil until it was coming out the same colour as I was putting It in. Then carry on as you was matt
	Threads: 465
114
Car Model/Spec: Vauxhall
		not gona happen this side of christmas!
	Threads: 0
45
		Prob best to paint it with white emulsion first too.
	Threads: 448
51
		Cambelt is definatley going to happen before I even start. I remember it was a good engine so I don't want to f*ck it by starting it with shit oil etc. especially as its been sat for at least a year
	Threads: 78
49
		Won't do any harm to start it with old oil mate, I'd at least get it warm and then drop it
	Threads: 448
51
		Oh really? May well have to go start it up for lols
	Threads: 136
11
		Disconnect the double relay (behind the ecu) and crank it over a few times until the oil pressure gauge shows some life,reconnect the relay and then start it.
