106 NAD, spotty? turbo?
no, i mean a 1.8 td pump!!
(15-10-2013, 07:33 PM)Piggy Wrote: no, i mean a 1.8 td pump!!
Exactly the same as a xud9 lol
doh. ah well
(15-10-2013, 06:09 PM)Dum-Dum Wrote: You might want to look and see if you can find a lower flowing fuel pump as IIRC samass had issues getting the fuel turned down enough when he first fitted the bosch for it not to coal on idle.
Coal on idle?? I left my Bosch at standard 1.9 fueling and was fine yer Smokey but not over the top, turned it down quarter of a turn and now hardly smokes at all just slight haze in people's lights behind me at night. The only down side to fitting the Bosch is my mpg's have gone down probably getting around 45mpg now compared to 56 when I was on standard lucus.
#35
hmmm.
mrs is managing 65mpg at the mo.
but Im hoping quick spooling boost and veg will keep the efficiency up and fuel costs low
ta for info chris...I didnt think it be an issue...did you gov mod the pump? thats the only mod I wana do to it
(15-10-2013, 09:16 PM)Piggy Wrote: hmmm.
Pump is completely standard apart from Fuel being turned down the tiny bit, (apart from all the grinding bits off lol)
Was thinking about gov mod but don't wanna do that till I got a rev gauge cos knowing me it will live at 6,000rpm
#37
for all you photo whores
[Image: 20131015_084356_zps96297dcb.jpg]
love the arch gap Undecided
Looks good with them defo needs lowering on front slightly
#39
Plan is standard gti suspension, be around 15/20mm
and all the plastics need 'back to blacking'!
(17-10-2013, 08:40 PM)Piggy Wrote: Plan is standard gti suspension, be around 15/20mm
Peanut butter, makes it smell nice Tongue
Also baby oil works aswell.
#41
I got some awesome stuff
Shoe polish last ages Smile ... Also are there any diffrences between 1.8 td injectors and 1.9.td Surely there will be mabey even straight 1.8 injectors ??7v
#43
duno but neither will fit the 1.5 head!
Remember that the pump I fist put on came straight of a stage 1 dt, and at any rate, didn't have "issues", just had to wind the screw back in.
FYI standard 106 bosch is an 8mm head
#45
good info sam. ta.
still on lookout for a 9mm pump.
looking too for a oil cooler setup...inc sandwich plate
How much modding did you have to do to get the Bosch on Sam?
#47
A fair bit, mainly the bracket on the head, hat was a lot of chopping to get it to fit on the block, and then to miss the rad. And the slam panel. Few pictures n my instagram and project thread
#48
(20-10-2013, 07:10 PM)samass Wrote: A fair bit, mainly the bracket on the head, hat was a lot of chopping to get it to fit on the block, and then to miss the rad. And the slam panel. Few pictures n my instagram and project thread
Cheers will have a nosey
interested to see what comes of this piggy giving me some inspiration
#49
some pics on my thread to Wink but sam did help me with advice on fitting it and pics Smile
#50
timings is more the issue...grinder takes care of the rest!
