wonder if its rusted from inside out.
best whip carpet out and look
Threads: 164
25
Car Model/Spec: Gti6
Will have to have a look see, was looking good when the carpet was fitted and its not been leaking for too long how long would it take to rust through?
Threads: 448
51
That doesn't look good! I'd get it welded asap, before it rusts more
Threads: 31
7
Definitely treat the rust and get it sealed! I'd also enquire as to where the leak is coming from, although it wouldn't surprise me if the pressure when driving is forcing the water up through the gap soaking into the carpet.
Heater matrix i have only known to affect the passenger footwell?
Threads: 226
24
Car Model/Spec: A3 TDi
Having experienced a heater matrix go, they fill the passenger foot well first, then after a certain point it starts to fill the drivers side. But before all that you get steam pouring out the vents. Pretty unmistakable. My first 306 used to randomly fill the foot wells with water. Took it to a jet wash once blasted the shit out of everywhere and it was fine. Then one afternoon in the rain, i got in, and splash soak through me shoes lol. Sunroof drain offs or door seals i reckon!
Threads: 164
25
Seems to be running down from behind the centre console but it is only the drivers side, haven't seen any steam but I do seem to be loosing loads of water from the rad
Will pull the carpet up and have a look see when it's not raining
Threads: 35
looks like its been jacked up there maybe as its raised, either way that looks like alot of water! I would get it fixed asap tbh, as im sure youve seen the rust on mine!
CONVOI EXCEPTIONNEL
Threads: 164
25
I have indeed mate but its only appeared recently and I certainly haven't jacked it there.. Do get a lot of stones flicking up after being hit by the strut brace though
Hmm
Threads: 195
6
Car Model/Spec: 2000 Xs 1.8 16v
Does look like a big fuk off stone has hit it at some speed and travelled along the floor pan before hitting back on the ground! I don't so any other reason how that would just come about!
