Want to see some wet gash? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: Want to see some wet gash? (/showthread.php?tid=18017) |
Want to see some wet gash? - rocker8742 - 12-10-2013 http://youtu.be/D-mDsspOaig Not what you were expecting? Well this is what I have under the drivers footwell and the water dribbles out when you put pressure on the carpet Think the carpets wet because of the heater matrix causing the carpet to be saturated but I'm not sure what's caused this split? It's slightly back from the rail running across the chassis almost looks like its split on the join between that and the floor pan Advice? Expect it'll need some sort of welding and underseal is it worth leaving it as drainage until the matrix is done? To give a better idea of where it is RE: Want to see some wet gash? - Piggy - 13-10-2013 wonder if its rusted from inside out. best whip carpet out and look RE: Want to see some wet gash? - Scott - 13-10-2013 (13-10-2013, 06:50 AM)Piggy Wrote: wonder if its rusted from inside out.This! Want to see some wet gash? - rocker8742 - 13-10-2013 Will have to have a look see, was looking good when the carpet was fitted and its not been leaking for too long how long would it take to rust through? RE: Want to see some wet gash? - Matt - 13-10-2013 That doesn't look good! I'd get it welded asap, before it rusts more RE: Want to see some wet gash? - Rich306 - 13-10-2013 Definitely treat the rust and get it sealed! I'd also enquire as to where the leak is coming from, although it wouldn't surprise me if the pressure when driving is forcing the water up through the gap soaking into the carpet. Heater matrix i have only known to affect the passenger footwell? RE: Want to see some wet gash? - Tom - 13-10-2013 Having experienced a heater matrix go, they fill the passenger foot well first, then after a certain point it starts to fill the drivers side. But before all that you get steam pouring out the vents. Pretty unmistakable. My first 306 used to randomly fill the foot wells with water. Took it to a jet wash once blasted the shit out of everywhere and it was fine. Then one afternoon in the rain, i got in, and splash soak through me shoes lol. Sunroof drain offs or door seals i reckon! Want to see some wet gash? - rocker8742 - 13-10-2013 Seems to be running down from behind the centre console but it is only the drivers side, haven't seen any steam but I do seem to be loosing loads of water from the rad Will pull the carpet up and have a look see when it's not raining RE: Want to see some wet gash? - martyn92 - 14-10-2013 looks like its been jacked up there maybe as its raised, either way that looks like alot of water! I would get it fixed asap tbh, as im sure youve seen the rust on mine! Want to see some wet gash? - rocker8742 - 14-10-2013 I have indeed mate but its only appeared recently and I certainly haven't jacked it there.. Do get a lot of stones flicking up after being hit by the strut brace though Hmm RE: Want to see some wet gash? - martyn92 - 14-10-2013 Doesn't look too bad as long as you dont leave it too long
RE: Want to see some wet gash? - underground375 - 14-10-2013 Does look like a big fuk off stone has hit it at some speed and travelled along the floor pan before hitting back on the ground! I don't so any other reason how that would just come about! |
