	Threads: 70
10
Car Model/Spec: HDi Estate
	Given 9 thank(s) in 9 post(s)
		I've got my first MOT tomorrow on my 306, it's all in good shape pretty much, but  I've got  a mysterious rattle from the front, everything is tight as it should be, new balljoints drop links, track rod ends, p bushes, top mounts etc, it has just still got some odd noises coming from it!
It being an older car, as long as everything passes the wiggle test and no obvious corrosion, are these odd noises allowed? They are more apparent when driving, so in the static scenario of the MOT they shouldn't really be a problem?
It's a 2000 year car, and have taken the cat and the backbox out of it, so hopefully that will distract the tester enough (and still pass with those bits gone!)
81
		i think you just need one box in the exhaust to pass so should be fine! the mysterious noise could be the aftermarket cat knocking on the subframe? that seems fairly common!
	Threads: 70
10
		Can't take it home and still get the free retest though, but will be good to see it in black and white.
	Threads: 39
Car Model/Spec: P2 Dturbo
		i've never been charged for a retest
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped
95' 306 P1 DT - Onyx - Scrapped
97' 306 P2 DT - Silver - Scrapped
97' 306 P2 DT - Onyx - SORN awaiting scrap
81
		ive never been charged for a retest either.
	Threads: 70
10
		ahhh cool, I've not had a car tested in years, and my last truck failed in a pretty big way anyway!
	Threads: 343
15
	Given 3 thank(s) in 3 post(s)
		As above never known any one to charge a retest fee.
	Threads: 33
Car Model/Spec: 306 D-turbo/306 Rallye
		I work at a garage, never charge for retests, you get 10 working days, not including Saturdays to return
Blaze '6 and Blaze D-turbo!
	Threads: 78
49
		It depends on what it fails on, as a general rule if it needs to go back on the system - for instance brakes or emissions, then a partial fee will be charged. (If the car is taken away and brought back).
As usual though it may depend on the garage.
