	Threads: 17
Car Model/Spec: 93' 405 GLDT
		Evening all
Il get straight to the point
I was out with my dad earlier in his 306 on our way back to his farm.
Turned right into a bend not massively quick but about 40 and the rear just lost it.
We tried to recreate it turning left but couldnt get the car to do it.
It was like the drivers rear wheel completely lost it
I looked at the rear beam and couldnt see anything out of the ordinary??
Also when you brake from say 50ish the entire car shakes. Its that bad the dash shakes lol
Any help appreciated as im towing a quad tommorow
		rear beam mounts would be something I would check first
	Threads: 92
43
		Whole car shaking under braking, check your discs
	Threads: 183
20
	Given 8 thank(s) in 8 post(s)
		I wouldn't say beam mounts. They only affected mine when going over 70mph
	Threads: 87
48
		oil or derv on the road . . .
	Threads: 46
6
Car Model/Spec: Renault Scenic 2.0
	Given 6 thank(s) in 6 post(s)
		let off the throttle during the corner? lift off oversteer maybe... had it a couple of times in my ax, although the cazr shaking does sound like warped disc somewhere
Project: Formula Peugeot
		If the bearings in the beam have collapsed it could cause both these symptoms, got much camber on it? Can you move either of the trailing arms much?
