Threads: 96
1
This may be In the wrong section sorry if it is
Basically the search on taps talk is wank would just like to know what's the what's the best mods to make a stage 2 worth it I've just fitted and intercooler and am thinking about a new clutch is there anything else I need to do as I've heard boost controller and fuel rail ?? Any info would be much apreciated :-)
Threads: 541
124
Essentially all you need is a FMIC and a remap.
If you don't want to do the clutch you can get a limited torque stage 2 map.
You will need to wind the boost up on the turbo though.
Threads: 591
54
manual boost controller is easiest way to up boost.
but you do really wana consider a clutch change
Threads: 96
1
Right so far on the list
Boost controller - what's the safest boost to run ?
Clutch - what's the cheapest and best as I'm not looking for limited torque I want allllll the torques :-D
Threads: 591
54
without being blunt, you're asking very open ended questions there chap...
it be like asking whats the best sandwich.
first you need to get a budget and a goal. and then do some research and see if with your budget you can reach your goal
Threads: 202
58
Go and look in the guides section and do some research, there's plenty of information to be found with very little searching.
Threads: 541
124
(25-08-2013, 08:11 PM)Jukie88 Wrote: Right so far on the list
Run whatever boost your map is designed to run (your mapper will tell you this if they know anything about what they are doing) Personally im not keen on manual boost controllers
The Cheapest clutch is a CG clutch
The Best clutch is a Helix paddle
Threads: 591
54
...correction, panther clutch is dirt cheap.
but I would rather walk
Threads: 541
124
Sorry, I meant cheapest that will actually hold the power.
Threads: 96
1
Money isn't really an issue for the clutch as I see it as a good investment so think Itl be paddle clutch for me if I'm gunna do it may aswell go ball in
Is there any need for a boost controller at all then dum dum or am I Ok without ? Or could I adjust the actuator not very mechanically minded so I'm bit confident with fiddling with things Indont understand lol I'm more of a bodywork kinda guy XD
Threads: 541
124
There is no need for a boost controller. It's easy to adjust, it's just a threaded bar with a thumb screw and a 10mm on the gt15 or 2 10mms on the ko3
Threads: 591
54
I know its not difficult to adjust be a MBC isnt expensive and does help control the boost more effectively than just a tightened waste gate
Threads: 202
58
(25-08-2013, 08:55 PM)Jonny81191 Wrote: Go and look in the guides section and do some research, there's plenty of information to be found with very little searching.
You're asking questions that are very very basic and all explained in the guides section. Because IMHO if you're asking about the need for an mbc and maybe not understanding it properly, then you'll be struggling to fit a fmic or clutch.
Threads: 82
27
As dumdum said.. it's so simple to adjust the wastegate there's really no need for a mbc and it's definitely not 'easiest' by any means
Threads: 96
1
(26-08-2013, 08:11 AM)Jonny81191 Wrote: (25-08-2013, 08:55 PM)Jonny81191 Wrote: Go and look in the guides section and do some research, there's plenty of information to be found with very little searching.
Already fitted the fmic and no I don't understand the mbc hense the question and ATM I've only got access to this forum on my tapatalk and the search function is ass and just brings up random threads with no relevance to what I want some help with I understand its probably a pita hearing the same old questions, but would like to learn new things and be told what's best or even better link me to a thread ?? And I defo won't be fitting a clutch no where near that compitent
Threads: 591
54
just head to the guides section.
loads of info there
Threads: 79
17
Car Model/Spec: Down and out HDi racestate
Threads: 117
119
For future reference, try the guides section first.
