Stage 2 info - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Stage 2 info (/showthread.php?tid=16792) |
Stage 2 info - Jukie88 - 25-08-2013 This may be In the wrong section sorry if it is Basically the search on taps talk is wank would just like to know what's the what's the best mods to make a stage 2 worth it I've just fitted and intercooler and am thinking about a new clutch is there anything else I need to do as I've heard boost controller and fuel rail ?? Any info would be much apreciated :-) RE: Stage 2 info - Dum-Dum - 25-08-2013 Essentially all you need is a FMIC and a remap. If you don't want to do the clutch you can get a limited torque stage 2 map. You will need to wind the boost up on the turbo though. RE: Stage 2 info - Piggy - 25-08-2013 manual boost controller is easiest way to up boost. but you do really wana consider a clutch change Stage 2 info - Jukie88 - 25-08-2013 Right so far on the list Boost controller - what's the safest boost to run ? Clutch - what's the cheapest and best as I'm not looking for limited torque I want allllll the torques :-D RE: Stage 2 info - Piggy - 25-08-2013 without being blunt, you're asking very open ended questions there chap... it be like asking whats the best sandwich. first you need to get a budget and a goal. and then do some research and see if with your budget you can reach your goal RE: Stage 2 info - Jonny81191 - 25-08-2013 Go and look in the guides section and do some research, there's plenty of information to be found with very little searching. RE: Stage 2 info - Dum-Dum - 25-08-2013 (25-08-2013, 08:11 PM)Jukie88 Wrote: Right so far on the list Run whatever boost your map is designed to run (your mapper will tell you this if they know anything about what they are doing) Personally im not keen on manual boost controllers The Cheapest clutch is a CG clutch The Best clutch is a Helix paddle RE: Stage 2 info - Piggy - 25-08-2013 ...correction, panther clutch is dirt cheap. but I would rather walk RE: Stage 2 info - Dum-Dum - 25-08-2013 Sorry, I meant cheapest that will actually hold the power. Stage 2 info - Jukie88 - 26-08-2013 Money isn't really an issue for the clutch as I see it as a good investment so think Itl be paddle clutch for me if I'm gunna do it may aswell go ball in Is there any need for a boost controller at all then dum dum or am I Ok without ? Or could I adjust the actuator not very mechanically minded so I'm bit confident with fiddling with things Indont understand lol I'm more of a bodywork kinda guy XD RE: Stage 2 info - Dum-Dum - 26-08-2013 There is no need for a boost controller. It's easy to adjust, it's just a threaded bar with a thumb screw and a 10mm on the gt15 or 2 10mms on the ko3 RE: Stage 2 info - Piggy - 26-08-2013 I know its not difficult to adjust be a MBC isnt expensive and does help control the boost more effectively than just a tightened waste gate RE: Stage 2 info - Jonny81191 - 26-08-2013 (25-08-2013, 08:55 PM)Jonny81191 Wrote: Go and look in the guides section and do some research, there's plenty of information to be found with very little searching. You're asking questions that are very very basic and all explained in the guides section. Because IMHO if you're asking about the need for an mbc and maybe not understanding it properly, then you'll be struggling to fit a fmic or clutch. RE: Stage 2 info - Midnightclub - 26-08-2013 As dumdum said.. it's so simple to adjust the wastegate there's really no need for a mbc and it's definitely not 'easiest' by any means Stage 2 info - Jukie88 - 26-08-2013 (26-08-2013, 08:11 AM)Jonny81191 Wrote:(25-08-2013, 08:55 PM)Jonny81191 Wrote: Go and look in the guides section and do some research, there's plenty of information to be found with very little searching. Already fitted the fmic and no I don't understand the mbc hense the question and ATM I've only got access to this forum on my tapatalk and the search function is ass and just brings up random threads with no relevance to what I want some help with I understand its probably a pita hearing the same old questions, but would like to learn new things and be told what's best or even better link me to a thread ?? And I defo won't be fitting a clutch no where near that compitent RE: Stage 2 info - Piggy - 26-08-2013 just head to the guides section. loads of info there RE: Stage 2 info - Slam Wagon - 27-08-2013 Guides... RE: Stage 2 info - Poodle - 27-08-2013 For future reference, try the guides section first. |
