Threads: 130
82
Car Model/Spec: 106 GO-NAD
20-07-2013, 09:14 PM
(This post was last modified: 21-07-2013, 04:30 PM by samass.)
So I figured its about time I put together a project thread for the nad, seeing as most of you have seen it by now anyway.
So, I got her off Ed in November, had to put a new beam on for the MOT, amongst other minor things (MASSIVE props to Dan and Kez for helping me out with that, was a bit of a night mare!)
Niall has/had a video of the play in the rear beam, I was surprised it was still on!
Then in January, in the coldest week of the year, I went over to Ruan's and he helped me strap on the Bosch, chronic coal resulted, so wound out the fuel and left it at that for a bit while I collected parts.
Dynoed her with just the Bosch on, and made 90lbft and something like 65bhp, got the printout somewhere, but f*ck knows where!
After lots of fabrication with adapter plates and chopping up old exhausts and faffing about with oil lines and and gauges and other stuff, myself and Niall cracked on one saturday when we realised I actually had all the parts to make it work.
Drove it down to Incarnation at Brighton, broke down on the way after boosting past Niall in his '6, minor electrical fault, nothing serious. Broke down on the way back after boosting up behind Niall, oil line to the turbo ruptured, covering the engine bay in oil.. RAC were called, and in not true Top Gear fashion, Niall and Grant stuck around to laugh at me, which was nice.
As a result of that, she developed a slight bottom end knock, ho hum. Oh, also, at some point, one of the bolts holding in the pump fell out, went round the cam belt, snapped the pump pulley, and detensioned the belt. Stuck a new one on there, and she’s a bit tappy, but ran fine!
Took her up to PPCITP in may, took her round the track, COOKED her, oil temp at 135 degrees, water temp pegged at 120 degrees, so probably hotter, clutch was ruined, slipping like mad as soon as she got hot, but a cracking time anyway!!
(pic stolen from Dum Dum)
(pic stolen from Carl)
Had her on the dyno at the end of June, pulled 190lbft and possibly around 130bhp, but due to no rev counter I cant be sure of that result, but anyway, here's the graph.
Then there was Pugfest just gone, popped a boost hose on my first run, and then popped the head gasket on my second! Still, Ruan cranked the bolts back down and she made it up to Aberdeen, all be it while pissing oil everywhere, but made it nonetheless.
Videos of the hill runs at pugfest:
Currently she's broken, looks like this..
Sandwich plate on the oil filter wont seal, at all. Needs a new filter insert.
so if tl;dr
So the current spec is:
Engine:
1.5D 1547cc TUD5 engine, standard internals
9mm, gov modded Bosch VE from a 306 1.9dt
Standard lucas injectors
Gearbox mounted Garrett GT15, welded wastegate cuz I’m lazy
Rad from a BMW 318i
Custom welded inlet manifold
Boot mounted battery
Single 9” slim line fan
Suspension:
Lowered around 30mm on Eibach Pro Kit
266mm 306 XSI brakes up front
Toyo Proxes on 15” 406 steels painted gold
Interior is partially stripped out, with gauges for Volts, Oil Temp, Water Temp and Boost
aaaaaaaaaand one last pic, mainly cuz I love the pic and i love to whore it out
Threads: 186
38
Car Model/Spec: MG ZR VVC
20-07-2013, 09:31 PM
(This post was last modified: 20-07-2013, 09:36 PM by Poodle.)
Oh snap!
Left out a bit of detail mate (cough bodges cough), but good to finally see this up!
Threads: 90
Epic project, really really epic, just what its all about. Bigger blower!!!!
Threads: 130
82
(20-07-2013, 09:23 PM)lolsteve Wrote: ABOUT TIME!
haha whatever man, you knew it already after pugfest, surely??
(20-07-2013, 09:31 PM)Poodle Wrote: Oh snap!
Left out a bit of detail mate, but good to finally see this up!
detail? what detail? tbf theres far too much to remember lol
(20-07-2013, 09:32 PM)darrenjlobb Wrote: Epic project, really really epic, just what its all about. Bigger blower!!!!
haha cheers man, oh yeah, forgot a future plans bit, which include, oil cooler, intercooler, and of course, bigger blower well, mildly bigger for now, been having naughtier thoughts, but need more research first
Threads: 195
6
Car Model/Spec: 2000 Xs 1.8 16v
First time ive seen a turbo and bosch on a nad loool well done!!!
Threads: 110
20
Got to love this!
I guess it wont be making it to FCS?
Can't see a few of the pics either dude.
Threads: 130
82
nope, even im not making it to fcs
balls, must be dropbox, ill fix it tomorrow, too much cba right now
Sucks you're not coming dude, doesn't look like i'll be coming up your way in August either now. You back down in September?
You beached bru?
Threads: 119
Car Model/Spec: MG ZS180
Will you ever get serious and go decomp and bigger turbo or you just sticking with what you got? Be interesting to see what it can do.
Threads: 130
82
20-07-2013, 09:48 PM
(This post was last modified: 20-07-2013, 09:49 PM by samass.)
awwwhhh maannnnn thats mega gay should be back in september tho
and nah, i wish i beached bru, im just wrecked!
(20-07-2013, 09:48 PM)Ricky Wrote: Will you ever get serious and go decomp and bigger turbo or you just sticking with what you got? Be interesting to see what it can do.
yeah i will, plan will be to get another engine and properly build it up and push it to see what can be done, but atm im skint, so im just doing basic stuff and trying to not push it to hard till i can really afford to proper r&d i want to
Sweet dude, and at least it'll be fun taking landys to bits in the meantime.
Hahah same, bedtime me thinks.
Threads: 130
82
yes, and oh hell yes!
Threads: 541
124
Awesome to see this up dude, one of the most inspirational cars on this forum, I love your stinky battered leaky red NAD.
Threads: 343
15
Given 3 thank(s) in 3 post(s)
Truly epic! That's all I got to say lol apart from sort the broken pics out wanna see them
Threads: 141
35
you mised out dash mounted jesus on the spec list. very important component of the gonad haha
great to see a project thread
Threads: 92
Car Model/Spec: Subaru 20.d, GTi 6, 205 xs
Samass loving the nad mate seen it a couple of times and it looks epic
Oh and theres a red nad by mine paints shitty with no tax or test £150
Current cars
Subaru Impreza 2.0d - Daily
Threads: 163
53
Car Model/Spec: 406 HDI
f*cking awesome, love the whole "lets see what happens" aspect!
Given 81 thank(s) in 77 post(s)
For those that havent seen this car, it really is truely epic! It just will not die no matter how much shit is thrown at it. Reminds me why i loved my old 106 again! (considering getting rid of the 6 for one as you cant have nice things without people trashing them )
Ill find the video of the beam later but it was well and truely f*cked lol. Will also find the few vids i have of first start with boost
Threads: 70
7
Car Model/Spec: Astor GTI6
Still can't beat PPC.
'Last time I saw this, it wasn't boosted'
Epic car!
Threads: 102
9
how far you going to go with the car? Ie are you going go full hog track car it etc
car with that power is a right hoot! my rover is!
Threads: 77
15
Been waiting for a build thread for this
First start
http://youtu.be/Da0NUcxSxY8
Broken down
Sam happy with his break down
And engine bay rust protecting its self
Threads: 3
7
Truly amazing...! Vids look good, shame you're not doing FCS...!
Threads: 130
82
(20-07-2013, 10:26 PM)Dum-Dum Wrote: Awesome to see this up dude, one of the most inspirational cars on this forum, I love your stinky battered leaky red NAD.
really?? cheers man!!
(20-07-2013, 10:30 PM)Chris_90 Wrote: Truly epic! That's all I got to say lol apart from sort the broken pics out wanna see them
thanks, i'll wok on the broken pics in a sec
(21-07-2013, 01:24 AM)ozonehostile Wrote: you mised out dash mounted jesus on the spec list. very important component of the gonad haha
ah yes, probably the main reason she still going!
(21-07-2013, 04:50 AM)Piggy Wrote: great to see a project thread
thanks, enjoy it
(21-07-2013, 06:28 AM)td_dan Wrote: Samass loving the nad mate seen it a couple of times and it looks epic
cheers for that dude, and cheers again for your help getting her thru the mot, couldn't have done it without you!
oh nice, could you pm me some details? might be an option
(21-07-2013, 09:01 AM)THE_Liam Wrote: f*cking awesome, love the whole "lets see what happens" aspect!
haha thanks buddy, that's pretty much been the whole idea of it!
(21-07-2013, 09:32 AM)Niall Wrote: For those that havent seen this car, it really is truely epic! It just will not die no matter how much shit is thrown at it. Reminds me why i loved my old 106 again! (considering getting rid of the 6 for one as you cant have nice things without people trashing them )
true that man, it'll be a shame if its the bloody filter insert that means the death of this engine!!
I found some of those early videos, this is how she sounded on idle:
and then the first drive on my private test track...
(21-07-2013, 09:48 AM)Carlos182 Wrote: Still can't beat PPC.
Epic car!
haha thanks man, it almost seems like it happened overnight!
(21-07-2013, 01:19 PM)procta Wrote: how far you going to go with the car? Ie are you going go full hog track car it etc
that's the eventual plan, want to fully strip and cage it, buckets, pedal boxes, fancy brake valves, nice suspension, alllll that jazz, all the while working and developing the engine, i think i need to win the lottery!
it's a right blast to drive now with the power, so responsive with the turbo too, power is almost instant, handling leaves a bit to be desired tho...
(21-07-2013, 01:32 PM)sam Wrote: Been waiting for a build thread for this
lol it seems a fair few people have been!
Nice one Niall, forgot about those other pics!!
(21-07-2013, 03:43 PM)Alee83 Wrote: Truly amazing...! Vids look good, shame you're not doing FCS...!
I know man, it sucks major aids
Threads: 77
15
Threads: 130
82
Yeah man, got pretty much all the bit think, probably just need some more clamps. Gunna get her running again first tho lol
Okay so tried to fix the images, has it worked?
Threads: 541
124
(21-07-2013, 05:01 PM)samass Wrote: Okay so tried to fix the images, has it worked? All working for me now babe x
