03-07-2013, 04:22 PM
I'm stuck on bedhamptonroad. Cars died. No engine. No apparent damage.
Ring me if you can assist!!!
broken down. need help asap
03-07-2013, 04:24 PM
I'm near thorney island
03-07-2013, 04:25 PM
If you were up my way I'd have come down, but you're a bit far! What happened just before it died?
I'd love to help, but you are close to the wrong island for me
03-07-2013, 04:29 PM
03-07-2013, 04:30 PM
Dunno. Powered on to make speed on the slip way. Engine light flashed on and it died instantly. No bangs or pops. No leaks underneath. Still turning over just not firing up
03-07-2013, 04:43 PM
I've had that a couple of times now. If I lock and unlock the car again, it will start. Have you tried that?
03-07-2013, 04:51 PM
Wish you'd have said about an hour ago, was over that way with Geli!
03-07-2013, 05:06 PM
Thank you Jonny! Your my hero! Aa has plugged in and pulled code p1112.
03-07-2013, 05:11 PM
Good to hear it's okay. Removed your phone number from the first post.
03-07-2013, 05:25 PM
Id of come down and helped if id seen this sooner honest
(03-07-2013, 05:11 PM)Scott Wrote: Good to hear it's okay. Removed your phone number from the first post. Just tried to delete it and you already have, Cheers scot!
03-07-2013, 05:28 PM
Yup, P0230 type o' thang. Lol, have fun with that.
03-07-2013, 07:41 PM
you get going again? i'm round the corner if you're desperate. Have not a clue about HDi's but got tools and a roof if you get stuck
Phaes 1 GTI 6 - Onyx Black
03-07-2013, 07:50 PM
All fixed now mate. Thanks for the offer
03-07-2013, 08:16 PM
Seriously, are we sure these constant P0230s and P1112s aren't down to lift pumps...
You've got a R70, no?
03-07-2013, 08:37 PM
No
Removed the frps and refitted it. Fired up straight away. AA just cleared the codes on the ECU for me! Going to get it of 2moro and give it a little spray with some leccy lube and refit it and cable tie it closed and secure
04-07-2013, 07:45 AM
Basically you panicked cos youre a massive pansy and couldn't fix a flat tyre by yourself. :p
Yeah. Panic first, fault find second
Well, answer the phone to Jonny 2nd!
04-07-2013, 12:22 PM
That is just round the corner from me lol.
Shame I didn't see it How come you're down this way?
15-07-2013, 03:40 PM
This has happened again! Fml
15-07-2013, 03:58 PM
Not sure. Pump wasn't priming and then it did. Think pump is on its way out. FCS is doubtful ATM
15-07-2013, 04:14 PM
(15-07-2013, 03:58 PM)Just Sean Wrote: Not sure. Pump wasn't priming and then it did. Think pump is on its way out. FCS is doubtful ATM Your coming to fcs one way or another. Ill come and get you if i have to!
15-07-2013, 04:40 PM
Thanks niall!
Got track time too! Gutted! |
