01-07-2013, 11:26 AM
		Hi guys, I've just been offered a set of 60mm lowering springs pretty cheap. Is 60mm too low? Not sure how it would look. Thanks
					Lowering
		01-07-2013, 11:57 AM
		well if you want to lower you car only by 30/40mm then yes it will be too low. however if you are wanting to lower you car by 80mm then its not far enough Wishes for more power...
		01-07-2013, 06:51 PM
	 (01-07-2013, 11:57 AM)Piggy Wrote: well if you want to lower you car only by 30/40mm then yes it will be too low. Sarcastic bastard! Theres 306s down further than 60mm mate, thats pretty common actually, can't see you having many issues...
		01-07-2013, 07:05 PM
		60mm is how much mines lowered by (at the front anyway, backs still standard at the moment, hopefully tackling that soon!), and its just right.    ![[Image: P1060836_zpsz3xgxt7q.jpg]](http://i1101.photobucket.com/albums/g427/wingnutz2/P1060836_zpsz3xgxt7q.jpg)
		01-07-2013, 07:42 PM
		Depends what size wheels you have. I have 17s and cant imagin going much lower than 60mm on front. Where as if you have 15s you have plenty of room
#2 Moonstone Blue HDI ![[Image: 6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg]](http://i512.photobucket.com/albums/t326/kent16_2008/6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg)
		01-07-2013, 08:18 PM
		that can depend on tyre size/profile though. a low profile on 17s could be same outer diameter as 15s with large profile tyres!
		02-07-2013, 05:55 AM
		Mines down about 60mm. Only time I encounter problems is with the lower brace on when tackling cushion speed bumps.
	 ![[Image: car-1.jpg]](http://i1117.photobucket.com/albums/k591/grant-306/car-1.jpg) Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
		02-07-2013, 11:32 AM
		Awesome, that's good to here, thanks guys   It should be lowered by the end of the week. I'll be sure to put some pictures up. I gotta find a decent set of wheels now, i was thinking of 15' steel wheels off a Partner van, in white, thoughts? |
