Threads: 110
20
So the S16 i brought the other day seems to have had a boost valve fitted. 1 like this http://www.ebay.co.uk/itm/350230965032?s...300wt_1018
I was just wondering if anyone has any experience with these and is it worth putting it on to mine
No.
These sort of things are crap. I played about with the rail pressure on my 1.8 a bit and had no end of troubles. The ECUs are just not advanced enough to adapt so it just throws a shit fit. Leave it be mate
Threads: 110
20
Ok cheers might chuck it on ebay some time
Threads: 110
20
Has anyone ever fitted 1 of these to there car?
Threads: 106
7
Car Model/Spec: GTi-6
I run one on mine, but it's too help fuelling with the cams I'm running... You need a remap ideally otherwise it'll totally ruin your air/fuel ratio.
JP
JP
Threads: 110
20
(21-04-2013, 04:52 PM)jammapic Wrote: I run one on mine, but it's too help fuelling with the cams I'm running... You need a remap ideally otherwise it'll totally ruin your air/fuel ratio.
JP
Ok cheers. When i drove the car which had it on i didn't think it went that well. Do you know if S16 ECU can be remapped?
Threads: 33
Car Model/Spec: 306 D-turbo/306 Rallye
Bit of an old thread but there is one of these fitted on my
Rallye, was on there when I got the car, no Idea if it helps or anything because I've never been in another 6/rallye, car does go quite well though!
Blaze '6 and Blaze D-turbo!
put it back to a standard FPR mate. If it hasnt been mapped in, it will only do damage in the long run.
Threads: 110
20
Dont think i am ever going to make use of it so is anyone interested in the boost valve?
Threads: 465
114
Car Model/Spec: Vauxhall
oww an ajustable FSE valve have you the blanking plug for the fuel rail too?
Threads: 122
9
He has the full kit off the car he broke
Threads: 110
20
I've just got the valve and some pipping that's in the pic. Also got some instructions that come with the car. If anyone wants if £10 and it's yours
Threads: 465
114
there should be a blank take off that fixes into the rail where the original fpr fits
Threads: 110
20
There is a bit that goes to the rail I think but it has a pipe going to it. I don't really have any knowledge of these things
Threads: 465
114
you need this bit or its pritty useles for the 6
Threads: 122
9
It was on the car when he drove it back from chard im 100 percent he has the whole kit
Threads: 106
7
FYI, you need a remap to go with one of these... without it, the AFR will be totally ruined and you'll either run rich and wash the bores out, or lean and kill the motor.
Only safe to use with a fully custom remap set up on the dyno or the road.
JP
Threads: 110
20
(22-06-2013, 07:23 AM)cully Wrote: you need this bit or its pritty useles for the 6
I've got that bit if its the same size for a 6 as a S16
Threads: 33
25-06-2013, 07:28 PM
(This post was last modified: 25-06-2013, 07:29 PM by Mitch.)
So does anyone have a standard one i could buy then? i have no idea if the car has been mapped or anything, it certainly does shift very well though and it runs spot on
