Has anyone had their XUD chuck a HDI rod?
Jut FYI, mine was running 182hp - 209.9hp depending on tune / boost for 18 months and it never went bang. I just never really revved it about 5k.
JP
JP
#32
Standard dhx with 180k, around 30psi and 170hp took 5k+rpm daily, never threw a rod its all in how its tuned imo though there was faulty ones from the factory it seems.
#33
(30-05-2013, 10:20 AM)Parksy87 Wrote: So far it settled it for me il definately be throwing the hdi rods in, ad aslong as i dont lock it up on oill n run 220 i should be ok so:
Rings
Shells
Valve stem seals
Crank seals
Cam seals
HG
Bolts
Anything else i should look at changing?
Im putting HDi rods in mine at the moment. Your best bet is to get piston rings, big end shell, HG, head bolts and just get a head set as that will have pretty much every other gasket you will need.
I got a victor reinz set and that looks pretty good tbf
